Risks of Resetting ECU
Old Jun 24, 2004 | 06:10 AM
Xenux's Avatar
Default Risks of Resetting ECU
Hi Guys,
I just upgraded my intake in my 99 Civic EX Coupe and the instructions say I can reset my ECU but at my own risk. It said to disconnect my negative battery cable for about 5 minutes. Is this accurate and if then what risks can I run into? I would greatly appreciate some assistance on this topic. Thanks for all your help!
Old Jun 24, 2004 | 06:11 AM
darkcvc's Avatar
Blue Sedan Crew
Default Re: Risks of Resetting ECU (Xenux)
i dotn think thier are any risks, jsut do it
Old Jun 24, 2004 | 06:19 AM
bbarbulo's Avatar
I'm guessing the warning may relate to something else, like... work on your own car at your own risk kinda thing... we're not responsible if you fall into the engine bay
but yeah, there is no risk involved... just disconnect the (-) battery terminal and go toss off a batch. when you come back, start the car WITHOUT touching the gas for the first few minutes... once the revs drop (ie. car is in feedback loop) go for a little boot around the block.
Old Jun 24, 2004 | 06:52 AM
Jimmy's Avatar
Global Moderator
You can't go wrong with resetting your ecu.
Old Jun 24, 2004 | 06:57 AM
jmjmotorsport's Avatar
Default Re: (Jimmy)
Yeah, in fact it's recommended you disconnect your negative terminal when you do *any* engine work just so that the ECU will reset and adjust for your mods.
Old Jun 24, 2004 | 07:02 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (jmjmotorsport)
Only downs to resetting the ECU:
1. If you have a factory radio with a code, you will need to have that code ready because disconnecting the negative cable will rest the radio.
2. If you have to pass emissions the ECU will not communicate with the emissions scanner until you drive the car for a a while
Other than that it's not a big deal really. You can also pull the ECU fuse from the underhood fuse box for a few minutes and it should rest the ECU as well.
Old Jun 24, 2004 | 07:06 AM
AutoXer's Avatar
Default Re: (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
Other than that it's not a big deal really. You can also pull the ECU fuse from the underhood fuse box for a few minutes and it should rest the ECU as well.</TD></TR></TABLE>
I had asked a honda tech at the dealer how to reset my misfire code after getting a shitty aftermarket dizzy cap wet. I specifically asked how long I needed to leave the neg off to reset the ECU, and he told me the way they do it at the dealer is to take both terminals and touch them together to reset. Tried it, and it worked great, no waiting.
Old Jun 24, 2004 | 08:19 AM
mjrage's Avatar
Default Re: (EX_AutoXer)
why would touching the terminal together do anything? There is no charge with battery not connected? Maybe by the time you disconnect both sides(starting with the negative) and then the positive, touching, reconnecting it would be the time interval if just disconnecting the negative.
If it works it works, ill be doing that after my ECT gets fixed.
Old Jun 24, 2004 | 08:55 AM
AutoXer's Avatar
Default Re: (mjrage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjrage &raquo;</TD></TR><TR><TD CLASS="quote">why would touching the terminal together do anything? There is no charge with battery not connected? Maybe by the time you disconnect both sides(starting with the negative) and then the positive, touching, reconnecting it would be the time interval if just disconnecting the negative.
If it works it works, ill be doing that after my ECT gets fixed.</TD></TR></TABLE>
I have no idea how or why it worked, but it only took me about a minute to disconnect, touch together, reconnect. I checked the codes about a week later, and everything had been cleared.
Old Jun 24, 2004 | 08:57 AM
Turbo E's Avatar
id rather pull fuses
Old Jun 24, 2004 | 08:58 AM
dropd4door's Avatar
cant you reset the ecu by taking it unpluging the ecu for a few minutes also?
Old Jun 24, 2004 | 09:02 AM
93Civac's Avatar
Yeah but when you plug it back in it might get sudden power and may cause damage.
Old Jun 24, 2004 | 09:03 AM
EL Vap133's Avatar
Default Re: (ON-THE-FLOOR4DOOR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ON-THE-FLOOR4DOOR &raquo;</TD></TR><TR><TD CLASS="quote">cant you reset the ecu by taking it unpluging the ecu for a few minutes also?</TD></TR></TABLE>
I heard that you can.
Old Jun 24, 2004 | 09:08 AM
dropd4door's Avatar
i doubt causing damage because my ecu gets unplugged everynight, and about 20 other people i know take theres in wit them everytnight
Old Jun 24, 2004 | 09:23 AM
aphex23's Avatar
only prob i have ever had with resetting my ecu, is it resets my damn stero, i hate having to go through and redo all the settings! other than that, as all the others have said, i highly doubt there are any other drawbacks..
Old Jun 24, 2004 | 10:13 AM
barto's Avatar
Default Re: (aphex23)
the only risk they were talking about that i would imagine would be getting shocked or something. so if you arent a complete idiot, youll be fine
Old Jun 24, 2004 | 10:41 AM
jeffk182's Avatar
The way I learned is disconnect the negative and then press the brake to turn on the brake light and remove all power from the system. Then wait a few min then plug everything back up and let it idle for a few min and then go drive.
Old Jun 24, 2004 | 11:14 AM
ironballz's Avatar
Default Re: (jeffk182)
my helms says to unplug back-up ecu fuse for 3 mins then plug back in.
Old Jun 24, 2004 | 11:43 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffk182 &raquo;</TD></TR><TR><TD CLASS="quote">The way I learned is disconnect the negative and then press the brake to turn on the brake light and remove all power from the system. </TD></TR></TABLE>
I'm assuming that's why touching the teminals together works, by instantly draining all power by grounding all systems together.
Old Jun 24, 2004 | 12:36 PM
Two_K Si's Avatar
Default Re: (ironballz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironballz &raquo;</TD></TR><TR><TD CLASS="quote">my helms says to unplug back-up ecu fuse for 3 mins then plug back in.</TD></TR></TABLE>
Thats how i do it. I wonder why techs at honda are telling people to unhook the battery when it states in the honda service manual to pull the fuse.
EDIT: Helms states to only unplug the fuse for 10 seconds.
Old Jun 24, 2004 | 01:31 PM
Andy M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjrage &raquo;</TD></TR><TR><TD CLASS="quote">why would touching the terminal together do anything?</TD></TR></TABLE>
There are capacitors throughout the system which remain charged for a while after unplugging the battery. Especially the relatively large ones in the radio.
Old Jun 24, 2004 | 01:35 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Only downs to resetting the ECU:
Or you can buy a memory holder and plug it in..
they can be found for like 2.99 at pepboys.
Old Jun 24, 2004 | 01:36 PM
mjrage's Avatar
Default Re: (jazzman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jazzman &raquo;</TD></TR><TR><TD CLASS="quote">
There are capacitors throughout the system which remain charged for a while after unplugging the battery. Especially the relatively large ones in the radio. </TD></TR></TABLE>
thanks. learning new stuff everyday.
cr_rex
Jan 11, 2006 08:07 AM
Unlimitationz
May 16, 2005 08:03 AM
dvcart106
Aug 9, 2003 12:42 PM
RIX982DRLS
May 13, 2003 12:23 PM
jermothedrunk
May 29, 2002 10:04 PM
