Engine help
Old Jun 23, 2004 | 05:54 PM
Restored_CRX_SI's Avatar
Default Engine help
my engine light came on my 88 Si. I didn't know you could find the problem out by counting the blinks on the ECU.
MY PROBLEM is I shut the car off and now I cant get my engine light to come back on so I can find the problem. I tried disconnecting the battery, and connecting it again but that doesn't work.
I know somethings wrong with the car because it hesitates around 2000 rpms and the exhaust pipe smells like gas and I get smoke coming out of it at about 5000 rpms. I don't think it burns gas because I just had it E-tested.
How do I get the engine light to come back on.
Thnakz in ADVANCE
( X-ques my spellin and gramer)
Old Jun 23, 2004 | 07:08 PM
Redline130's Avatar
Default Re: Engine help (Restored_CRX_SI)
Just drive it around until the engine light comes on again. Then find someplace to park and check the ecu for the code. Disconnecting the battery will reset the ecu, btw.
Old Jul 4, 2004 | 06:39 PM
My engine light came on and I pulled out the code........ OXYGEN CONTANT or code 1...
I have no Idea what this means...... Is it im not getting enogh air or to much air.
Anyone had this problem and how to fix.
Thanz in ADV
Old Jul 4, 2004 | 06:52 PM
EF9Si-T's Avatar
Seems to me that your oxygen (02)sensor is going bad. Just get one from your nearest parts store and replace it. It should cost you about $40 give or take a few. Once your done take of the hazard fuse out for about 10 seconds and VOILA your done.
scorched0's Avatar
check your Oxygen sensors...located on the exhaust manifold.
xpoisnfreex
Dec 29, 2008 12:54 PM
hkhaperey
Apr 30, 2007 07:15 AM
integra_type-r
Dec 14, 2004 04:04 PM
EKtypeRhaTcH
May 2, 2003 08:03 PM
eg686
Apr 18, 2003 01:01 PM
