what rod bearings do use for my eagle rods in my b18b?
Old Jun 21, 2004 | 04:20 PM
ls95hatch's Avatar
Default what rod bearings do use for my eagle rods in my b18b?
i am stalled in the process of putting eagle h beams in my b18b block. does anyone know which color bearings to use? i do not have my old ones to look at. thanks
Old Jun 21, 2004 | 04:28 PM
BatuKing's Avatar
Default Re: what rod bearings do use for my eagle rods in my b18b? (ls95hatch)
Get Standards.. dont buy Dealer bearings given I doubt you can color match them to fit.
Old Jun 21, 2004 | 04:42 PM
chad's Avatar
Moderator
Default Re: what rod bearings do use for my eagle rods in my b18b? (BatuKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing &raquo;</TD></TR><TR><TD CLASS="quote">Get Standards.. dont buy Dealer bearings given I doubt you can color match them to fit.</TD></TR></TABLE>
you obviously don't know how to do it right!!!
don't get standard bearings....do it the right way and clearance them in!!!
Old Jun 21, 2004 | 04:47 PM
BatuKing's Avatar
Default Re: what rod bearings do use for my eagle rods in my b18b? (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
ok how to clearance them? or you talking measure them and use the honda chart for fit? Last time I saw a honda chart it only gave you a reference of number and letter to get a color to purchase.
I usually use ACL standard bearings and have yet to have a problem with fit on my engine rebuilds
Old Jun 21, 2004 | 05:58 PM
ls95hatch's Avatar
i bought acl bearings and they were way off. so does anyone know the sizes that go with the colors?
Old Jun 22, 2004 | 08:32 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls95hatch &raquo;</TD></TR><TR><TD CLASS="quote">i bought acl bearings and they were way off. so does anyone know the sizes that go with the colors?</TD></TR></TABLE>
What do you consider way off?
Old Jun 22, 2004 | 08:41 AM
9seccivicsi's Avatar
plastiguage them or use some sort of measuring tool because the bore on the eagle rod may not be the same as standard!!
Old Jun 22, 2004 | 08:56 AM
USDM 4G VTEC's Avatar
i got Clevite STD size bearings with my eagles on the D16Z6
the clearance were perfect... on the .2 side
i say, get standard, plasti gate them, and go from there into oversize or something
Old Jun 22, 2004 | 12:41 PM
chad's Avatar
Moderator
Default Re: (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">the clearance were perfect... on the .2 side
that is not perfect for a car that you want reliability on!! hUnda recommends .0013
Old Jun 22, 2004 | 02:36 PM
Default Re: (chad)
that is not perfect for a car that you want reliability on!! hUnda recommends .0013</TD></TR></TABLE>
i am at work and dont have the specs with me
i had it on the plastigate 2 bar ( 0.02, 0.002, 0.2 wichever, i cant remember now, u should know what i mean)
wich means u have it on the loose side a lil bit
Honda makes the clearances to last on a motor for 200k miles
if u want peak performance u want it a lil looser than stock to get better lubrication, less friction and best response
way before this engine reaches another 100k , i will be rebuilding it again.....
so whats ur point?
Old Jun 22, 2004 | 02:41 PM
RyanEJ8's Avatar
Default Re: (chad)
What makes you think the clearances that Honda recommends for a STOCK engine will be good for an engine designed for high performance with aftermarket parts?
Sketch_hs
Mar 1, 2006 07:07 PM
EKB18BPR3
Jul 18, 2004 05:06 PM
EKB18BPR3
Jul 10, 2004 10:20 AM
shermanyang
Aug 17, 2002 08:19 AM
