Going to the Dyno on Monday 28th with leaky HG
ok, I KNOW its not a great Idea to dyno with a leaky HG. here's the thing my compression is over 210 across the board and the HG seems to leak intermittantly.
I only get bubbling in the overflow under HARD driving. will the leaky HG severely afffect my dyno performance and tuning.
I am working a car show this weekend and only have sunday to put on a new HG maybe.
do you think i can get away with torqing down the head studs 5lbs more?
mind you I have already rescheduled once already.
I only made 188WHP cuz i didnt realize my plug gaps were too big and my O2 was Bunk (universal bosch
specs:
JDM B18C
Hondata S200 with boost
Hondata Intake Manifold gasket
RC 550 cc fuel injectors
Greddy Turbo Kit (TD 05 18G)
Blitz DD Blowoff valve
ACT Street clutch w/Xtreme pressure plate
10 lb OEM flywheel
NGK sparkplug wires - NGK BKR7E 0.030" gap
B&M Fuel pressure regulator (38 PSI)
Crane Hi-6 Ignition - Crane PS91 external coil
Trust Intercooler (type 31)
Autometer 20 PSI boost gauge
HKS manual boost controller set at 10 PSI
Skunk2 adjustable cam gears
Custom 2 1/2" Dynomax exhaust and downpipe
Neuspeed 2 1/2" lowering springs
Koni shocks
Revolution 15" wheels /Toyo T1S 195/50/15
Stock internals (don't try this at home)
Stock steering wheel (airbags save lives)
Best time at track: 13.5@105 MPH on street tires
BTW check your plug gaps cuz they DO change a bit over time
)specs:
JDM B18C
10 lb OEM flywheel
Koni shocks
If you have the HG, I say change it. The slow leak may turn into a larger leak causing you to damage your engine. Besides, it only takes a couple hours if you've done it before.
i say if you dont have a hg then buy one and change it you would just be wasteing your money going to the dyno. the head gasket will effect your power and performance , you will have to replace it anyways
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by feri0 »</TD></TR><TR><TD CLASS="quote">
and im glad u posted stock steering in ur mod's list
you welcome, now go hit a tree. you can have a nice "MOMO" imprinted on your forehead to impress the ricers
</TD></TR></TABLE>you welcome, now go hit a tree. you can have a nice "MOMO" imprinted on your forehead to impress the ricers
Go out and purchase a new one or if you have one replace it.your spending money on a dyno session why do it with a leaky HG doesn't make sense.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 »</TD></TR><TR><TD CLASS="quote">you welcome, now go hit a tree. you can have a nice "MOMO" imprinted on your forehead to impress the ricers</TD></TR></TABLE>
and u can have a nice HOMO, bwahaha, i win, game over.
norcalcrx
Jul 17, 2011 04:27 AM
yoorang
Sep 17, 2006 09:44 PM
