Check Engine Light on
Old Jun 20, 2004 | 09:05 AM
ex96vtec's Avatar
Default Check Engine Light on
I own a 98 honda civic ex, ever since installing a new exhaust the check engine light is on, is there a way to make this light go off. I know that its on because of the new exhaust.
esoterEK..'s Avatar
Default Re: Check Engine Light on (JohnV)
maybe o2 sensor u might not connect it
Old Jun 20, 2004 | 09:07 AM
dogfood's Avatar
first of all grab the code. Then let me guess and say that it's a code 65(secondary o2 code). but before that get the code and go from there
Old Jun 20, 2004 | 09:55 AM
ex96vtec's Avatar
I also plan on putting on an AEM short ram intake, should I wait until its on to do anything about the check engine light?
Old Jun 26, 2004 | 11:16 AM
dogfood's Avatar
putting an intake on your car will have nothing to do with needing to ge that cel fixed. The cel is on because of the exhaust. The intake won't change that.
Old Jun 26, 2004 | 03:53 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: Check Engine Light on (dogfood)
CEL = BAD, fix that before you throw any more money at the car.
Old Jun 26, 2004 | 04:02 PM
specv5150's Avatar
Default Re: Check Engine Light on (HondaFanatic708)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 &raquo;</TD></TR><TR><TD CLASS="quote">CEL = BAD, fix that before you throw any more money at the car.</TD></TR></TABLE>
well not always
I have a CEL 13 and 63 and my car runs great. Code 13 is from the AFC hack and 2ndry O2 doesnt bother anything
Old Jun 26, 2004 | 04:36 PM
97ShLude's Avatar
Default Re: Check Engine Light on (specv5150)
Well since he has an OBDII car and he has vtec, throwing the secondary O2 sensor code will not let vtec engage which = no fun!
Use a jumper to pull the code and fix the problem before you do anything else.
Try resetting the ECU by unhooking the negative terminal of the battery for a couple seconds, then try and see if it is still throwing the CEL.
If that doesn't work it's probably an O2 sensor problem.
Old Jun 26, 2004 | 04:40 PM
specv5150's Avatar
Default Re: Check Engine Light on (97ShLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ShLude &raquo;</TD></TR><TR><TD CLASS="quote">Well since he has an OBDII car and he has vtec, throwing the secondary O2 sensor code will not let vtec engage which = no fun!
Use a jumper to pull the code and fix the problem before you do anything else. </TD></TR></TABLE>
Really? I never noticed because my SOHC VTEC-E doesnt make a noticeable difference when vtec engages
Old Jun 26, 2004 | 04:44 PM
97ShLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">
Really? I never noticed because my SOHC VTEC-E doesnt make a noticeable difference when vtec engages</TD></TR></TABLE>
I'm pretty sure of it. Just like when an OBDII car gets a test pipe, you must get an O2 sensor simulator or vtec won't engage and the car will run like ***.
Old Jun 26, 2004 | 04:47 PM
specv5150's Avatar
I'm pretty sure of it. Just like when an OBDII car gets a test pipe, you must get an O2 sensor simulator or vtec won't engage and the car will run like ***.</TD></TR></TABLE>
NOPE. I am OBDIIB and my car runs like a champ with the O2 sensor ziptied in the engine bay
Old Jun 26, 2004 | 05:00 PM
97ShLude's Avatar
NOPE. I am OBDIIB and my car runs like a champ with the O2 sensor ziptied in the engine bay</TD></TR></TABLE>
Well then the guys at R and D Motorsports are wrong (Chad), highly unlikely.
But why is it that when you purchase a test pipe for an S2K ( and OBDII car ) that you must get the O2 sim. for vtec to engage.
Old Jun 26, 2004 | 05:05 PM
specv5150's Avatar
But why is it that when you purchase a test pipe for an S2K ( and OBDII car ) that you must get the O2 sim. for vtec to engage.</TD></TR></TABLE>
I dont know. S2K vs civic.....?? No clue. But I DO know my 2ndry O2 sensor is ziptied in my engine bay and my car runs like a champ. It was my impression that the 2ndry O2 sensor was basically there to let you know your cat converter is doing its job (or not). I could be wrong. I dont really know. All I know is my car runs good. Actually I know another guy who has his O2 sensor ziptied in his engine bay and his car runs great
Old Jun 27, 2004 | 10:08 AM
ex96vtec's Avatar
Thanks guys, I recently got a secondary o2 simulator = no check engine light thanks again
Old Jun 27, 2004 | 10:33 AM
rusted_eyes's Avatar
Not always, I cruise w/ my check engine light on .(mfg. emmissions)
Old Jul 1, 2004 | 07:13 PM
dogfood's Avatar
I have a secondary o2 on my mini-me because I haven't wired in the o2 and my vtec engages
jst17
Acura TSX
Mar 25, 2014 06:16 AM
Kris's turbo
Apr 10, 2009 07:24 AM
dvonghalath
Sep 2, 2008 07:31 PM
wilsel
Apr 15, 2005 05:18 AM
PM-Performance
Nov 30, 2001 10:53 AM
