What should I do?
Old Jun 17, 2004 | 08:30 PM
david90's Avatar
Default What should I do?
My axle has 106k on it and its boot is on the verge of spliting. My axle has no problem nor make any sound.
Should I change the boots or get a reman axle from autozone?
Basicially what i'm asking is, is a 106k axle with new boots better than a reman axle from autozone.
Old Jun 17, 2004 | 08:37 PM
mmuller's Avatar
Mad Scientist
Default Re: What should I do? (david90)
just replace the boots.
if treated right that oem axle could last like another car life
Old Jun 17, 2004 | 11:34 PM
rubix777's Avatar
Default Re: What should I do? (mmuller)
just new boots
Old Jun 18, 2004 | 08:46 AM
senpai's Avatar
New boots if you do it yourself, a shop will charge more than what a reman. axle will cost just to replace the boots (ask me how I know!)
Old Jun 18, 2004 | 08:47 AM
MightyMouseTech's Avatar
I would MUCH rather have an OEM joint with 100k on it than a P.O.S. reman joint from autozone.
Old Jun 18, 2004 | 09:18 AM
senpai's Avatar
Default Re: What should I do? (MightyMouseTech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote">I would MUCH rather have an OEM joint with 100k on it than a P.O.S. reman joint from autozone.</TD></TR></TABLE>
What's the diff? I've always used reman. axles and they have a lifetime warranty as well
Old Jun 18, 2004 | 12:55 PM
mmuller's Avatar
Mad Scientist
Default Re: What should I do? (maztur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur &raquo;</TD></TR><TR><TD CLASS="quote">
What's the diff? I've always used reman. axles and they have a lifetime warranty as well</TD></TR></TABLE>
lifetime waranty or not, oem is a lot better quality
i use autozone axles too, but i could afford it oem would be nice.
i have a set of stock axles with 160k, all i did was replace the booths and repack with grease and still going strong
Old Jun 18, 2004 | 02:13 PM
RCautoworks's Avatar
If you know the old axle that is spitting grease out did not go a long time with no grease left, get it repacked. But if you drive on it and there is not enough grease inside, the joint will over heat and fail sooner or later.
Old Jun 18, 2004 | 03:55 PM
Quitripin's Avatar
Old Jun 18, 2004 | 11:07 PM
david90's Avatar
any tips for a mess free cv boot repacking? What do you use to clean the joint with?
Old Jun 19, 2004 | 08:14 AM
91civicDXdude's Avatar
in my experience, replacing the boot always ends up badly, with the CV joint eventually going bad anyways. I would replace the entire axle and have piece of mind.
chances are that if the boot is torn and grease is leaking out, then dirt has gotten in and that means death for your CV joints.
Old Jun 19, 2004 | 03:30 PM
david90's Avatar
Default Re: (91civicDXdude)
grease hasn't leaked yet.
Pwnmeister
Jun 25, 2013 07:55 AM
usafstud
Honda S2000
Sep 17, 2011 04:18 AM
drewcandraw
Jan 29, 2007 07:17 PM
ahloung
15
Mar 14, 2006 11:52 AM
athoughts
16
Sep 27, 2005 12:49 PM
