93 civic vx wiring
Old Jun 17, 2004 | 05:40 PM
URBAN TANK's Avatar
Default 93 civic vx wiring
I was wondering if the civic vx wiring harness with the vtec will work
or do i need to change the harness
Old Jun 17, 2004 | 07:20 PM
VTECVillain's Avatar
Default Re: 93 civic vx wiring (b204d)
The VX harness can be used for nearly any swap, especially for a DOHC VTEC B series motor. You will need to rewire for a 4 wire O2 setup, other than that it's as good as any other VTEC engine harness.
Old Jun 20, 2004 | 02:21 PM
URBAN TANK's Avatar
Default Re: 93 civic vx wiring (VTECVillain)
will the ecu work i will only be using it for a short time i plan on going with a hondata or an aem
Old Jun 21, 2004 | 05:59 PM
URBAN TANK's Avatar
ttt
Old Jun 21, 2004 | 10:08 PM
Combustion Contraption's Avatar
get a p28 or even cheaper, a pr4.
Old Jun 22, 2004 | 05:27 AM
Default Re: (LsVtec92Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">get a p28 or even cheaper, a pr4.</TD></TR></TABLE>
Not following here.... a PR4 is an OBD0/OBD1 Integra nonVTEC B18A1 ECU. The VX ECU is made to run basically only the D15Z1 VX motor. Of course the ECU can be chipped like a P28 to DOHC VTEC specs though.
Old Jun 22, 2004 | 10:44 AM
since he stated his intention was only to run on the ecu for a short while and then go with AEM EMS, i said the obd1 pr4 was an option only because it will run the car fine if he doesnt go nuts with it and they are pretty cheap.
slowbluhatch
Apr 13, 2005 07:34 AM
gnar kill
10
Nov 19, 2004 02:29 PM
meanTheDope
Apr 28, 2004 08:58 AM
dremmel
Mar 1, 2004 09:17 PM
Motorvated
Aug 19, 2003 01:33 PM
