What sound deadener?
Old Jun 17, 2004 | 02:05 PM
s2kds's Avatar
Default What sound deadener?
Well I have heard of all kinds. Is there a difference? What do you use and why? How much of my delsol should I do? I have an all Alpine sys. 9833 headunit ,Type R 6.5 all around, and one 10" R in the trunk. Also I have a little rattle comming from the trunk area, will sound deadening stop this? Thanks.
Old Jun 17, 2004 | 04:01 PM
EBP_SI's Avatar
Default Re: What sound deadener? (delsol8694)
Modified by EBP_SI at 3:26 AM 6/18/2004
Old Jun 17, 2004 | 06:12 PM
From: eating the shit out of pizza in raleigh, NC, USA
Default Re: What sound deadener? (EBP_SI)
stick with Dynamat Extreme
Old Jun 17, 2004 | 08:50 PM
o_Rage_o's Avatar
Default Re: What sound deadener? (2ndchancehonda)
go cheap - brown bread...just about as effective, with a MUCH better adhesive than dynamat.
However, dynamat - even the original, works nicely as an aperiodic membrane since its softer...the brownbread is thinner, and about 3/4's as heavy....but the price makes up for it - you could always double up on trouble areas.
-rage
Old Jun 17, 2004 | 10:01 PM
erikiksaz1's Avatar
Default Re: What sound deadener? (o_Rage_o)
..or raamatt (or raamatt, forgot how it's spelled)
Old Jun 18, 2004 | 05:16 AM
bassisliffe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by EBP_SI at 3:26 AM 6/18/2004</TD></TR></TABLE>
take it you changed your mind?
Old Jun 18, 2004 | 05:51 AM
Goatsterrman's Avatar
Default Re: What sound deadener? (bassisliffe)
I have 70 ft of BrownBread in my car, very nice stuff. It can get a little messy on the install, but if you take your time it is easy to use. And like previously stated, the adhesive is bit better than the dynamat.
Old Jun 18, 2004 | 10:19 AM
itr_dc2's Avatar
Default Re: What sound deadener? (Goatsterrman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Goatsterrman &raquo;</TD></TR><TR><TD CLASS="quote">I have 70 ft of BrownBread in my car, very nice stuff. It can get a little messy on the install, but if you take your time it is easy to use. And like previously stated, the adhesive is bit better than the dynamat.</TD></TR></TABLE>
Yup!
Old Jun 18, 2004 | 03:41 PM
s2kds's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o_Rage_o &raquo;</TD></TR><TR><TD CLASS="quote">- you could always double up on trouble areas.</TD></TR></TABLE>
where are the "trouble areas"?
Old Jun 19, 2004 | 10:07 AM
s2kds's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsol8694 &raquo;</TD></TR><TR><TD CLASS="quote">
where are the "trouble areas"?</TD></TR></TABLE>
Old Jun 19, 2004 | 11:34 AM
o_Rage_o's Avatar
behind the rear speakers on both side is an open cavity, also the door panels make a good difference. While your doing the doors, also take off the window rubber track, get some weatherstriping cement, and cement it back on.
I didn't follow my own advice, and my rubber came of the damn track....and it's all covered mat.....ugh....
-Rage
Old Jun 20, 2004 | 01:28 PM
loulax07's Avatar
Default Re: (civic_rice)
If it's a rattle, you better going with open-cell foam in that area. do deaden a panel, u'd use mass-loading or stuff like dynamat.
I've used Dynamat, Raammat, Brown Bread, Edead.....
this is what I did:
Rammatted my upper reear deck. Used Brown Bread on the lower of my rear deck. and used LIQUID Edead V3 in my trunk. I also have 2 layers in my doors.... I've used Second Skin's Rattle Pad where I have rattle and now it is gone.
and yes, u dont need Dynamat, Brown Bread will work just as good, trust me,
Check out my www for detailed install pics of deadening. http://www.sounddomain.com/id/loulax07
to be safe and what would work best, is a sheet of deadening then foam on top
OH, and OSU SUX!!!!! GO BLUE!!!!!!!!!!!!!!!!
Old Jun 20, 2004 | 04:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_rice &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=798297</TD></TR></TABLE>
best thread EVER!!!!!!!!!!!!!!!
daddy
Audio / Security / Video
Dec 4, 2007 04:41 AM
02AccordBigBoi
16
Aug 10, 2005 02:41 PM
bassisliffe
17
Dec 11, 2004 08:59 PM
02AccordBigBoi
16
Oct 27, 2004 11:39 AM
jordan-boxer
12
May 8, 2004 02:48 PM
