Engine Noises or bad connection possibly???
Old Jun 17, 2004 | 04:57 PM
liitezout's Avatar
Default Engine Noises or bad connection possibly???
Recently in the past week i have had bad distortion in my speakers..i just bought Pioneer front speakers in my 95 coupe...but the distortion is still there...maybe its a bad connection? any suggestions would be good..
Old Jun 17, 2004 | 08:38 PM
fcm's Avatar
fcm
Old Fart
Default Re: Engine Noises or bad connection possibly??? (liitezout)
Or outputs that have gone west. 94
Old Jun 17, 2004 | 08:41 PM
KTeller8's Avatar
Default Re: Engine Noises or bad connection possibly??? (fcm)
also check your grounds..
Old Jun 18, 2004 | 12:47 AM
LSP's Avatar
LSP
what kind of distortion? if its engine noise then it might be bad wiring. Discribe it best you can, ill check back and help you out later.
Old Jun 18, 2004 | 05:13 AM
bassisliffe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liitezout &raquo;</TD></TR><TR><TD CLASS="quote">Recently in the past week i have had bad distortion in my speakers..i just bought Pioneer front speakers in my 95 coupe...but the distortion is still there...maybe its a bad connection? any suggestions would be good..</TD></TR></TABLE>
do you have an amp or are runing from the headunit?
if so change it and install amps, problem must go away
Old Jun 18, 2004 | 06:27 AM
debogsr's Avatar
maybe its your cd player. When burned cd's get old, they start to distort and sound bad
Old Jun 18, 2004 | 08:57 AM
spark plugs.
Guest
Posts: n/a
Default Re: Engine Noises or bad connection possibly??? (debogsr)
if you give a better description of the 'distortion' (any non-natural signal is considered distortion), then there wouldn't be so many shots in the dark. all of the above suggestions are possible, though. Don't run and install amps until you know exactly what the problem is.
Old Jun 20, 2004 | 12:09 AM
KTeller8's Avatar
Default Re: Engine Noises or bad connection possibly??? (spark plugs.)
for example, i get "engine noise"
high pitched sound created when i press the pedal.
a lot of times its higher pitched and louder when the AC is on.
if not its a consistant whine.. then gets loud as pedal is pushed
Old Jun 20, 2004 | 07:29 AM
Default Re: Engine Noises or bad connection possibly??? (KTeller8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by debogsr &raquo;</TD></TR><TR><TD CLASS="quote">maybe its your cd player. When burned cd's get old, they start to distort and sound bad</TD></TR></TABLE>
wow, that explains it! (talking about my situation btw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spark plugs. &raquo;</TD></TR><TR><TD CLASS="quote"> Don't run and install amps until you know exactly what the problem is.</TD></TR></TABLE>
i was telling him to change the rado and install amps, but you are right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">for example, i get "engine noise"
if not its a consistant whine.. then gets loud as pedal is pushed</TD></TR></TABLE>
you are the person with this problem?
that sounds like bad ground i had the same problem but a pyramid noise suppressor quickly solved that
and i don't think it affected the way my music plays anyway
might want to try a better brand though
Old Jun 20, 2004 | 01:21 PM
KTeller8's Avatar
Default Re: Engine Noises or bad connection possibly??? (bassisliffe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe &raquo;</TD></TR><TR><TD CLASS="quote">
might want to try a better brand though </TD></TR></TABLE>
no not me.. "for example"
Old Jun 20, 2004 | 04:12 PM
oh ok
Blue Cups
Audio / Security / Video
Nov 4, 2016 04:00 PM
Quick99Si
Mar 20, 2007 03:54 AM
PM-Performance
Oct 24, 2004 11:44 AM
articbluedc5
Oct 8, 2004 10:09 AM
shyboy817
13
Jul 10, 2004 08:57 AM
