14B wastegate
Old Jun 17, 2004 | 09:45 AM
vbphreak's Avatar
Default 14B wastegate
Searched but no luck.
Can I replace the stock wastegate (remove it) and use an aftermarket one instead? TIA
Old Jun 17, 2004 | 11:30 AM
sporkcrx's Avatar
Default Re: 14B wastegate (vbphreak)
Aftermarket one, like an external?
Old Jun 17, 2004 | 12:23 PM
hotintegranights's Avatar
Default Re: 14B wastegate (sporkcrx)
if you want more boost out of it theres a place around that only sells dsm stuff that sells one that starts you up at 17psi. if you want to lower boost just shorten the rod on the wastegate, as far as putting an external one that ll be a biatch.
Old Jun 17, 2004 | 12:33 PM
vbphreak's Avatar
Default Re: 14B wastegate (hotintegranights)
Yes. I did mean external.
I'm not looking to increase the boost. The turbo i'm looking at doesn't come with the stock wastegate. I'm thinking that it'll be better to just get something external so that i can adjust the boost later on if i want to increase it eventually.
Old Jul 1, 2004 | 04:22 PM
jok's Avatar
jok
a 14B Comes with a stock wastegate, infact I got mine with one the more exact code TD05H turbo. Try searching the web for DSM (diamond Star Motors) websites for parts new and used, try ebay as-well you never know what you can find.
N20civicB18
Dec 27, 2006 09:22 AM
fkneh
Oct 11, 2005 03:55 AM
KURUPTinc
Jul 12, 2005 01:04 PM
yorktonite
Aug 20, 2002 04:37 AM
