timing question
Old Jun 16, 2004 | 03:21 PM
wpgcivic's Avatar
Default timing question
hey guys is there a way that my timing could still be fine by using a timing light but it still have skipped a tooth?
Old Jun 16, 2004 | 03:54 PM
wpgcivic's Avatar
ttt
Old Jun 17, 2004 | 04:31 AM
JimBlake's Avatar
Default Re: (wpgcivic)
If your cam timing is one tooth off, there's maybe enough adjustment at the distributor to set your spark timing correctly. Is that what you're asking? Or are you confusing spark timing with camshaft timing?
Old Jun 17, 2004 | 05:57 AM
wpgcivic's Avatar
well my buddy checked the timing by looking at the pulley which you usually do with the timing gun but i am trying to figure out why my b16 is so slow and i was thinking maybe the belt skipped a tooth
Old Jun 17, 2004 | 06:11 AM
civicgsr's Avatar
You could probably tell that the cam timing is off by looking at the mark on the pulley. However, I don't know that you can accurately figure out how far off you are. If you checked the timing and the marks are correct, you'll need to look elsewhere.
I would pop off the valve cover and check the orientation of the cams to the crank. You could even pop off the cover on the distributor, and check to see if it's pointing at #1.
Also, make sure your VTEC is kicking in.
-Alex
Old Jun 17, 2004 | 06:18 AM
wpgcivic's Avatar
vtec is kicking but yeah i am going to take off the valve cover and check for TDC
Bassy_budz
68
Dec 16, 2013 08:38 AM
dem0nk1d
Jun 27, 2012 12:39 PM
BoostedH
Dec 9, 2008 10:34 PM
NatedoggAZ
14
Apr 13, 2005 09:51 AM
speedaccordinly24
Apr 21, 2003 08:10 AM
