Need help
Id try to get one for a 1994 Del Sol VTEC from an auto parts store or the dealer, thats going to be your safest bet, also, are you sure your knock sensors bad, did you check the wiring at the ecu? You could also try to retard the timing to reduce detonation, loosen the to and bottom 12mm bolts at the distirbutor and turn it clockwise ( toward the front of the car) to retard the timing, that might help narrow it down.
Modified by b16aCivicEF at 5:06 AM 6/15/2004
juiceman33
May 2, 2005 07:53 PM
