ECU Code and Engine question
Old Jun 12, 2004 | 12:42 AM
sexualbanana's Avatar
Default ECU Code and Engine question
I swapped a JDM B18C1 into my EK hatch and I'm running the JDM B18C1 ecu.
My CEL light is on. When I check the code, I get 2 codes.
One code is for the electric load detector. What does that mean? Does it have anything to do with the fact that we used the distributor from my D-Series? Don't ask why, because I forget the reason why we used the D distributor.
The other code says I'm running rich or lean. My exhaust doesn't seem to be blue, so I don't think it's rich. What could be the cause? Could it be because I'm using the fuel pump from the D?
One more question.
Is there a power difference between the USDM B18C1 and the JDM B18C1? A friend of mine told me the JDM's are pushing close to 200hp. I think he's full of crap.
Old Jun 12, 2004 | 08:58 AM
Default Re: ECU Code and Engine question (sexualbanana)
Anyone? No one?
Old Jun 12, 2004 | 09:00 AM
esoterEK..'s Avatar
is it a code 91?
https://honda-tech.com/zerothread?id=767817
Old Jun 12, 2004 | 10:15 AM
jensen's Avatar
JDM B18C's dont run much different than the US ones. I don't know the specs but they sure feel the same. LOL. What are the exact engine codes?
Old Jun 13, 2004 | 10:49 AM
Default Re: ECU Code and Engine question (jensen)
Code 20 and 45
Old Jun 13, 2004 | 11:00 AM
skip.two's Avatar
ECU code thread.
https://honda-tech.com/zerothread?id=682412
code 20 Electrical load detector
code 45 Fuel system too rich or lean
change your distributor to the right one. not sure whats the cause, but hope you find out.
code 20 threads...
https://honda-tech.com/zerothread?id=885328
https://honda-tech.com/zerothread?id=882551
https://honda-tech.com/zerothread?id=874122
code 45 threads...
https://honda-tech.com/zerothread?id=746142
https://honda-tech.com/zerothread?id=670385
couldn't find many, so goodluck
scrambled_EG
Oct 9, 2009 06:42 PM
Blind_Attack
Apr 11, 2006 01:10 PM
RedStarGsr
Feb 18, 2004 09:39 PM
SolidSpruce
Apr 23, 2003 05:33 PM
tz-devil77
Jan 21, 2003 12:37 PM
