ECU Code and Engine question
I swapped a JDM B18C1 into my EK hatch and I'm running the JDM B18C1 ecu.
My CEL light is on. When I check the code, I get 2 codes.
One code is for the electric load detector. What does that mean? Does it have anything to do with the fact that we used the distributor from my D-Series? Don't ask why, because I forget the reason why we used the D distributor.
The other code says I'm running rich or lean. My exhaust doesn't seem to be blue, so I don't think it's rich. What could be the cause? Could it be because I'm using the fuel pump from the D?
One more question.
Is there a power difference between the USDM B18C1 and the JDM B18C1? A friend of mine told me the JDM's are pushing close to 200hp. I think he's full of crap.
One more question.
ECU code thread.
https://honda-tech.com/zerothread?id=682412
code 20 Electrical load detector
code 45 Fuel system too rich or lean
change your distributor to the right one. not sure whats the cause, but hope you find out.
code 20 threads...
https://honda-tech.com/zerothread?id=885328
https://honda-tech.com/zerothread?id=882551
https://honda-tech.com/zerothread?id=874122
code 45 threads...
https://honda-tech.com/zerothread?id=746142
https://honda-tech.com/zerothread?id=670385
couldn't find many, so goodluck
code 20 threads...
code 45 threads...
