PLEASE help motor revs by itself!!!!
Old Jun 11, 2004 | 06:10 AM
gtowni3's Avatar
Default PLEASE help motor revs by itself!!!!
if i hold my foot at about 1500 rpm, the motor sounds like its revving up and down...up to like 1700 and down to 1500....should i just clean the iacv?!!
THANKS!
Old Jun 11, 2004 | 06:14 AM
Bodman's Avatar
Default Re: PLEASE help motor revs by itself!!!! (gtowni3)
bump for a good question. so it revs without you moving the peddle?EDIT: pedal
Old Jun 11, 2004 | 07:40 AM
gtowni3's Avatar
Default Re: PLEASE help motor revs by itself!!!! (Bodman)
yeah
Old Jun 11, 2004 | 07:57 AM
Maverik4k's Avatar
throttle needs to be timed and adjusted?
Old Jun 11, 2004 | 08:21 AM
jspresso's Avatar
Default Re: PLEASE help motor revs by itself!!!! (Maverik4k)
you could either have a vacuum leak or you will need an new idle motor. i used to have a eg ex and it did the same thing. how many miles are on it?
Old Jun 11, 2004 | 08:27 AM
VtecDeMoN's Avatar
Sounds like a vaccum leak to me. Turn your car on and take some carb cleaner and spray around on your intake manifold. If your engine surges while spraying you can isolate where the vaccum leak is. Also I don't know anything about your setup so I can't tell what intake manifold you are using, but if you are using a different throttle body on your intake manifold or vice versa you want to make sure that the tb gasket you are using matches the tb not the manifold. This can be a common source of vaccum leaks.
Brian
Old Jun 11, 2004 | 08:29 AM
OnePointFive's Avatar
overrated.
Default Re: PLEASE help motor revs by itself!!!! (VtecDeMoN)
vaccum leak.... have fun
Old Aug 24, 2004 | 04:44 AM
SSBPGSR's Avatar
Default Re: PLEASE help motor revs by itself!!!! (OnePointFive)
if it was a vacuum leak it would do it all the time. right?
Old Aug 24, 2004 | 05:24 AM
Phatch99's Avatar
Default Re: PLEASE help motor revs by itself!!!! (SSBPGSR)
try unplugging your idle air control sensor
TopGear_
Aug 18, 2009 11:15 AM
JDMCivic16
Jun 8, 2009 02:12 PM
jdmeg61
Oct 29, 2006 08:12 PM
xotixciv
Jan 24, 2006 08:58 AM
matto2413
Jun 1, 2005 11:36 PM
