ls vtec problem . help
Old Jun 6, 2004 | 05:56 PM
delsol1225's Avatar
Default ls vtec problem . help
can anyone help me with my problem?
i built an ls vtec motor containing a 96 gsr head
and a 94 ls block. my idling is too high. i don't know what to do.
i don't have check engine lights on my car. it idles at 2000 rpm.
the car runs fine except for the idling. please help
Old Jun 6, 2004 | 05:58 PM
mmuller's Avatar
Mad Scientist
Default Re: ls vtec problem . help (delsol1225)
have you checked for vaccum leaks?throttle cable too tight?
Old Jun 6, 2004 | 06:02 PM
delsol1225's Avatar
Default Re: ls vtec problem . help (mmuller)
yes, i check for vacuum leaks and the throttle body.
Old Jun 6, 2004 | 07:45 PM
1.8turbolsvtec's Avatar
what is the code that you are getting
Old Jun 12, 2004 | 09:14 PM
delsol1225's Avatar
Default Re: ls vtec problem . help (1.8turbolsvtec)
no codes
Old Jun 13, 2004 | 03:43 AM
SkRiBLaH's Avatar
make sure you have coolant flowing to the iacv,
if that no work, adjust the idle screw on the throttle body with a flat head screwdriver
Old Jun 13, 2004 | 05:59 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: ls vtec problem . help (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">adjust the idle screw on the throttle body with a flat head screwdriver</TD></TR></TABLE>
Old Jun 13, 2004 | 11:12 AM
Reason's Avatar
I had a similar problem on my ls/vtec. My problem was, i took my throttle body off and cleaned it. Then I went to a Honda dealership for the TB gasket but when I put it on my car started idling at like 2 grand. So I sprayed carbruetor cleaner all around the TB and found out that it was sucking air. So I took the TB back off and went to a different dealer and they told me that I had the wrong gasket. So I changed the gasket and problem went away. So if you have not checked the you might want to.
Old Jun 13, 2004 | 11:48 AM
delsol1225's Avatar
Default Re: (Reason)
I'll try that, thanks
ninthgatemotorsports
Apr 2, 2009 06:58 PM
GSR_hatch936
Jan 27, 2008 01:13 PM
hondajav06
Jul 24, 2007 11:42 AM
libral00
Jun 16, 2007 04:19 PM
vtecda
Aug 15, 2005 07:41 AM
