LS/VTEC IDLE PROBLEM
Old Aug 10, 2005 | 11:32 PM
vtecda's Avatar
Default LS/VTEC IDLE PROBLEM
so i just finished up my ls/vtec swap, fired it up and the idle raises to around 4000 and stays there.. i checked my vacuum routings, IAC, TPS, Throttle cable adjustment.. everything seems ok. i'm wondering if for some reason the ecu needs to relearn or maybe it's an intake manifold gasket or something... any help would be greatly appreciated
Old Aug 12, 2005 | 01:53 PM
LS_teg's Avatar
Default Re: LS/VTEC IDLE PROBLEM (vtecda)
damn thats a good ? im doin a LS/Vtec right know and i want to know the answer to this just in case this happends to me.
thanks for anyone who's answer's it
Old Aug 12, 2005 | 02:30 PM
decent's Avatar
i just finished wiring up my lsvtec had same problem mine went to 3k and held.........you need to adjust the engine idle screw by throttle body take the iac and tps off hold the trottle at around 1k rpm for a minute and slowly let the throttle down it should idle around 4-500 if not adjust the screw till it does after it is ideling where you want it shut the car off and pull the 7.5 fuse(forgot the name but its the one that controls the radio and clock...it says wich one on the fusebox cover) under the hood and hold it for 10-15 secounds while it sweeps the memory. then put it back in re-attach iac and tps and go fom there---i did this last night and this mourning. sorry if this is all running together i was trying to be fast.
regards, James
Old Aug 12, 2005 | 02:50 PM
riceball777's Avatar
the idea is adjustable at the throttle body in 2 places. you can set the idea at what ever rpm you want.
theres the idel screw thaty is for fine adjustment when can only adjust so much and theres the course screw that props the butterfly open by where the throttle cable is connected to the tb
Old Aug 14, 2005 | 10:08 PM
vtecda's Avatar
thanks alot guys.. i'm gonna try that tomorrow hopefully it will work. thanks!
Old Aug 15, 2005 | 07:41 AM
nickG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecda &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot guys.. i'm gonna try that tomorrow hopefully it will work. thanks!</TD></TR></TABLE>
that would have been the first thing i checked....
dark_reverie
Aug 15, 2014 12:39 PM
B18_badboy
May 1, 2011 04:43 PM
celticthor
Dec 12, 2008 11:18 AM
luda98
Oct 14, 2004 07:05 PM
sk8phaze
Aug 16, 2002 10:45 AM
