Why is the vacuum so low?!
Guest
Posts: n/a
i have a 1995 integra ls with a t3/t4 turbo. i am currently running it on a stock block but i am having one built by spark racing. the piston rings are shot and i am getting A LOT of blow by. my problem is that i noticed that the vacuum is at -15 mm/hg. i always thought that it should be at -20 at idle. correct me if i'm wrong. i've went over every single vacuum hose and see now leak. does anyone have any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by troublecodes »</TD></TR><TR><TD CLASS="quote">i have a 1995 integra ls with a t3/t4 turbo. i am currently running it on a stock block but i am having one built by spark racing. the piston rings are shot and i am getting A LOT of blow by. my problem is that i noticed that the vacuum is at -15 mm/hg. i always thought that it should be at -20 at idle. correct me if i'm wrong. i've went over every single vacuum hose and see now leak. does anyone have any ideas? </TD></TR></TABLE>
That has to do with the timing being off you get that alot on some cars with thick headgasket you just have to make some adjustments
