idle problem after tonight
Old Aug 20, 2006 | 11:45 PM
zexifiedlude's Avatar
Default idle problem after tonight
aight well im coming back from the movies tonight and the grl i was with loves the sound of my bov, so i boosted here and there a couple times thus increasing my chances for something later in the night.....
anyway after the last time i hit boost my idle went all to ****. no matter what i do (clutch in, clutch out) the idle bounces from 1k to 3k none stop. driving is semi normal... whats could that idle mean?? thanks for all the input a heaf of time
Old Aug 21, 2006 | 12:01 AM
komat's Avatar
Default Re: idle problem after tonight (zexifiedlude)
vacuum leak
one of your vaccum hose blew off
Old Aug 21, 2006 | 03:57 AM
F20Cteg's Avatar
Default Re: idle problem after tonight (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">vacuum leak
one of your vaccum hose blew off</TD></TR></TABLE>
&gt;&gt;&gt;&lt;&lt;&lt;
Old Aug 21, 2006 | 01:12 PM
yeah i found it today, it was a vac leak except not in a vac line... what it was, was the drain plug in my catch can fell out... cause i was like wtf is there oil around my catch can and then i saw a hole in it lol.. all fixed now!!
Old Aug 21, 2006 | 01:13 PM
thanks for all the help guys
Old Aug 21, 2006 | 02:32 PM
komat's Avatar
Default Re: (zexifiedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zexifiedlude &raquo;</TD></TR><TR><TD CLASS="quote">yeah i found it today, it was a vac leak except not in a vac line... what it was, was the drain plug in my catch can fell out... cause i was like wtf is there oil around my catch can and then i saw a hole in it lol.. all fixed now!!</TD></TR></TABLE>
that shouldnt cause your idle to surge. how is your catchcan hooked up?
Old Aug 21, 2006 | 07:54 PM
Default Re: (komat)
that shouldnt cause your idle to surge. how is your catchcan hooked up?</TD></TR></TABLE>
pcv to catch can, catch can to intake manifold
Old Aug 22, 2006 | 12:01 AM
F20Cteg's Avatar
pcv to catch can, catch can to intake manifold</TD></TR></TABLE>
That is too emission friendly. Just vent it. Blowby vapors mess with the A/F and lower the effective octane of the fuel.
Old Aug 22, 2006 | 09:15 AM
Default Re: (F20Cteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20Cteg &raquo;</TD></TR><TR><TD CLASS="quote">
&gt;&gt;&gt;&lt;&lt;&lt;</TD></TR></TABLE>
by vent u mean???
Old Aug 22, 2006 | 09:18 AM
igo4bmx's Avatar
pcv to catch can/ plug up the port on the IM
Old Aug 22, 2006 | 09:26 AM
Default Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">pcv to catch can/ plug up the port on the IM</TD></TR></TABLE>
i tried doing that before, i did, pcv to catch can, catch can to pre turbo, and blocked off the IM and my car started acting crazy after that, idle dropped tremendously and it would stall if in high speed i drop it into neutral
Old Aug 22, 2006 | 09:28 AM
turbotime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zexifiedlude &raquo;</TD></TR><TR><TD CLASS="quote">i tried doing that before, i did, pcv to catch can, catch can to pre turbo, and blocked off the IM and my car started acting crazy after that, idle dropped tremendously and it would stall if in high speed i drop it into neutral</TD></TR></TABLE>
you musta hooked something up wrong, doing it pcv-&gt;oil catchcan and intake blocked off should/could not cause those symptoms....
ninjaedit: you need to make sure the 2nd nipple on your catchcan is open, so if your can has 2 nipples:
nip1: to pcv
nip2: open w/breather filter
im: plugged
vc nip: open w/breather filter
96hatchBoy
Mar 28, 2013 06:17 AM
darkstar90
Apr 26, 2007 10:57 PM
XstouterX
Nov 11, 2005 11:30 PM
b18-c-rx
Aug 2, 2005 12:06 AM
slammin86
13
Jan 9, 2004 05:36 PM
