DPFI to MPFI Conversion Problem
Old Jun 5, 2004 | 12:38 PM
Turbo-King's Avatar
Default DPFI to MPFI Conversion Problem
I converted my 1990 Civic Dx to MPFI and it just so happens that plug B12 on the ECU already has an existing wire. So I followed the instructions for the conversion and I'm still having drivability problems. Hard starting, runs like S*** and it won't rev past 3500 rpm for some mysterious reason. I think it's probably running in limp mode from a code that the ECU is throwing for a screwed up crank angle or cylinder sensor. They're both located in the distributor and it's brand new. Would anyone happen to know what the wire that's sitting in B12 is used for? I've done this swap before and never had a problem but none of them had ever had a wire in pin B12 and this is the only thing i can think of that's screwing everything up. Anyone ever have these symptoms happen before?
crxvtecturbo
11
Sep 2, 2006 12:05 PM
Cprace1
Nov 18, 2005 03:41 PM
shivern
Mar 6, 2005 03:23 PM
pro547
11
Feb 25, 2005 11:21 AM
