Control arm question
Old Jun 4, 2004 | 11:53 PM
egamjah's Avatar
Default Control arm question
aright, so my dumb *** hit a curb going about 30 mph straight on. my steelies got bent a bit, and were losing air. so i picked up some ls rims from a friend, and now im on those. but now my steering is messed up. while im going straight, it seems fine, but if i turn it a little to the left or right, it cuts by itself. my front left tire also rubs, and it makes a squealing noise. looking at my car straight on, my camber also seems to be a bit off.
from what i can tell, and have been told, it seems to be a bent/damaged control arm. what should i expect to pay to have a good mechanic repair/replace something like this?
Old Jun 5, 2004 | 01:24 AM
KNO3's Avatar
Default Re: Control arm question (egamjah)
If the control arm is bent, you would probably replace it. You can probably get one at a junkyard for anywhere between $45-$60 approx. It's actually not that hard to replace it but if your going to pay someone, then another $40-$60 sounds right.
Old Jun 5, 2004 | 11:04 AM
egamjah's Avatar
Default Re: Control arm question (KNO3)
hrm wow, my friend who drives a 2000 civic coupe says he payed around 750 to get one control arm fixed.... you think maybe he was just majorly ripped off?
Old Jun 5, 2004 | 11:31 AM
KNO3's Avatar
Well, in my experience, that's how much I payed. Just get one of those neighborhood mechanics to do it. Because if you go anywhere like a shop, they might charge a lot.
Old Jun 5, 2004 | 11:42 AM
s2k drifter's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egamjah &raquo;</TD></TR><TR><TD CLASS="quote">hrm wow, my friend who drives a 2000 civic coupe says he payed around 750 to get one control arm fixed.... you think maybe he was just majorly ripped off?</TD></TR></TABLE>
I think you should tell your friend to get the mechanic in a headlock and ask for his money back. I replaced the right lower control arm in my stuffy *** garage myself in less then hour with soda breaks and little snack. KNO3 is pretty much accurate with the price of the control arm and also that is pretty much what it cost to have it installed by a shop. You can always do this yourself or with a buddy, not hard at all.
Old Jun 6, 2004 | 12:03 AM
egamjah's Avatar
Default Re: Control arm question (EK project hybrid)
aright, so i asked him again, and now he tells me they replaced the control arm, the tie rod, and some type of bearing. with all this stuff, is it still reasonable that he payed around 750 bucks?
Old Jun 6, 2004 | 12:05 AM
FifthGearOnline's Avatar
i have both stock front UPPER control arms off my 99 DX for sale.... 50 bux + shipping
I take paypal if your interested
Old Jun 6, 2004 | 03:05 AM
EE_Chris's Avatar
~$100 for the upper control arm.
~$150 for the lower control arm.
~$30 for the outter tie rod.
~$60 for a hub bearing.
These are just off of San Leandro Honda parts
To replace the hub bearing, I'm pretty sure he had to remove the whole knuckle in order to do it.
Did the $750 include an alignment as well?
Old Jun 6, 2004 | 12:05 PM
egamjah's Avatar
Default Re: Control arm question (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Did the $750 include an alignment as well?</TD></TR></TABLE>
not sure.... il ask him next time i see him, he tends to forget to put important details into his stories.... he said he got it done at an amoco, or mobil or something
Old Jun 6, 2004 | 12:52 PM
elwood's Avatar
not sure.... il ask him next time i see him, he tends to forget to put important details into his stories.... he said he got it done at an amoco, or mobil or something</TD></TR></TABLE>
For 750$ You could get a full gsr front suspension from a junkyard and
figure out how to install it yourself. I put on a swaybar and changed everything
you say may be bent with no mechanical skill or training in my gravel driveway.
Take the bolts out, put stuff on, put bolts back in. Its not like your fabricating
something together, its all bolt on stuff, and then go get a good allignment.
Old Jun 6, 2004 | 01:15 PM
dantastic's Avatar
Default Re: Control arm question (elwood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elwood &raquo;</TD></TR><TR><TD CLASS="quote">For 750$ You could get a full gsr front suspension from a junkyard and
figure out how to install it yourself. </TD></TR></TABLE>
i got a whole gsr front sub frame with brakes and upper control arms and knuckles for $125 from hmotorsonline. i ran into a curb going about 40mph, at about a 20degree angle... i snapped my front LCA, broke 1 rota, and bent my rear spindle. i have the entire gsr front suspension in, incl oem integra lower strut bar and front sway bar, and gsr brakes now. took me about a whole afternoon with just hand tools. now i just need to get a rear disc swap
Old Jun 6, 2004 | 01:22 PM
null.'s Avatar
Default Re: Control arm question (dantastic)
wow 750$ could have saved a little more and do a 5 lug conversion haha
Jaydeep
Honda Civic (2001 - 2005)
Aug 8, 2010 08:30 PM
my95civic
Aug 13, 2004 09:44 AM
alexngo
Jul 6, 2004 07:43 PM
xteg95
Nov 18, 2002 10:47 PM
