surging idle after obd2-obd2 conversion.
Old Jun 4, 2004 | 04:29 PM
DOMKID's Avatar
Default surging idle after obd2-obd1 conversion.
Im running a 97 b18b. Car is running perfectly fine with obd2 LS ecu. Now i tried running an obd1 LS ecu and i get a surging idle from 1k-1.5k. Are there any sensors that are different?
Modified by Dominican_Kid at 5:47 PM 6/4/2004
Old Jun 4, 2004 | 08:22 PM
DOMKID's Avatar
Default Re: surging idle after obd2-obd1 conversion. (Dominican_Kid)
bump.
I lowered the idle and managed to get a normal idle when the motor is at normal temp. However, when it's cold it still surges. My TB doesnt have a FITV, so im guessing it may be the iac but it was working fine?
any suggestions?
thanks.
Old Jun 4, 2004 | 08:55 PM
3rdGteg's Avatar
somebody help this guy out
friend got the same problem...
Old Jun 4, 2004 | 11:28 PM
RedZone's Avatar
Default Re: surging idle after obd2-obd1 conversion. (3rdGteg)
Your on the right track, its just the FITV or the lack there of......your car will run fine.
Old Jun 5, 2004 | 12:53 AM
3rdGteg's Avatar
Default Re: surging idle after obd2-obd1 conversion. (RedZone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedZone &raquo;</TD></TR><TR><TD CLASS="quote">Your on the right track, its just the FITV or the lack there of......</TD></TR></TABLE> So your saying it's surging and idling high because he doesn't have the FITV??
Old Jun 5, 2004 | 01:45 AM
RedZone's Avatar
yes that is what I am saying. An OBD2 car does not have FITV and handles its idle functions through the IAC where as OBD1 cars have a FITV and the ECU is awear of this and handles idle differently throught the IAC. make an sense? I hope i did'nt confuse anyone because i think i just confused myself!!!
Old Jun 5, 2004 | 03:14 AM
DOMKID's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedZone &raquo;</TD></TR><TR><TD CLASS="quote">yes that is what I am saying. An OBD2 car does not have FITV and handles its idle functions through the IAC where as OBD1 cars have a FITV and the ECU is awear of this and handles idle differently throught the IAC. make an sense? I hope i did'nt confuse anyone because i think i just confused myself!!! </TD></TR></TABLE>
sweet, thanks for the info. I will try to get a TB with FITV.
Old Jun 6, 2004 | 09:49 PM
DOMKID's Avatar
fitv is a mechanical piece,so i dont think it will fix my problem. Any other suggestions?
Old Jun 6, 2004 | 09:53 PM
RedZone's Avatar
I know its not an electrical sensor but the ecu is still going to compinsate somewhat for it being there with the IAC, the other thing you can try is the PCV valve.....I had a surging idle on a prelude the other day and it happened to be the PCV valve was bad, check that!
ill look for more things to try!
Old Jun 8, 2004 | 06:29 PM
Mighty's Avatar
I have the same problem. Surging idle when running a chipped P28. So we are sure its this FITV thing?
Old Jun 8, 2004 | 06:39 PM
Katman's Avatar
Sometimes, idle issues can be an unfixable problem when converting to OBD1. Usually it only happens when the car is cold, such as what you're experiencing -- you'll just have to live with the idle fluctuations.
happens a lot too, when OBD2 civic/integra owners convert to OBD1 and run an chipped P28, P72, P30, etc, ecu's...
Old Jun 8, 2004 | 06:41 PM
3rdGteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedZone &raquo;</TD></TR><TR><TD CLASS="quote">the other thing you can try is the PCV valve.....I had a surging idle on a prelude the other day and it happened to be the PCV valve was bad, check that!</TD></TR></TABLE>
Old Jun 9, 2004 | 02:20 PM
DOMKID's Avatar
i tried a new PCV and the problem still occured. I tried the ecu in my buddys car and it started doing the same thing. I think the ecu is bad.
thanks for all the info guys.
Old Jun 9, 2004 | 11:00 PM
3rdGteg's Avatar
Thanks Jeremy (RedZone), I finally solved my problem after months of messing with it He is the fukken shiznit
.....damn pcv wasn't even inline with the system.
pork
Sep 24, 2007 09:46 AM
Eran
11
Aug 9, 2006 11:33 PM
Argetnia
Oct 16, 2005 04:22 PM
baphomet
Nov 3, 2003 01:20 PM
IWearMyKswiss
Oct 9, 2001 07:47 PM
