Help with 92 DX wont start
Old Jun 4, 2004 | 02:44 PM
jackzzz's Avatar
Default Help with 92 DX wont start
I have fuel and spark, But wont start . Any ideas on where to go from there ?
Will the injectors not work with a bad ecm? I sprayed gas in throttle body and still nothing?
Thanks
Jac
Old Jun 4, 2004 | 04:38 PM
jackzzz's Avatar
Default Re: Help with 92 DX wont start (jackzzz)
ttt
Old Jun 5, 2004 | 01:42 AM
KNO3's Avatar
I can help. Be more specific though. Does your engine turn over?
Old Jun 5, 2004 | 09:28 AM
jackzzz's Avatar
Default Re: Help with 92 DX wont start (KNO3)
Hello , yes it turns over and has spark,fuel to the fuel rail . Sprayed fuel in throttle body and still nothing happening. could this be the ecm ? i thought it would run without the ecm disconnected? Or i was thinking it could be the dist. is shot but in that case i shouldnt be getting spark.
Old Jun 5, 2004 | 11:26 AM
KNO3's Avatar
Open up your distributor. Check all your connections. If they're all fine, then you know it's not due to a poor connection. Take out your ignition control module and ignition coil. Get these tested. It might be one of these two components. Also, if it turns over, you might have a blown ignition fuse. It's under your steering column.
Old Jun 6, 2004 | 01:38 PM
jackzzz's Avatar
Old Jun 6, 2004 | 01:53 PM
mjrage's Avatar
you mean the ECU? Could be the main relay.
Old Jun 6, 2004 | 06:39 PM
jackzzz's Avatar
Default Re: Help with 92 DX wont start (mjrage)
Will the main relay make the fuel injection not work? I have spark and fuel to the injectors It should start. What does the main relay control?
Thanks
Jac
Old Jun 6, 2004 | 07:07 PM
mjrage's Avatar
PGM-FI or Program Fuel Injection is the main relay basically. It controls ignition, fuel pump, etc.. It could cause that problem or it could just be a distributor cap and rotor. Have you tried that?
Main relay will be anywhere from 35-65$ . I just bought one. I only could get it thru honda.
Old Jun 6, 2004 | 07:32 PM
jackzzz's Avatar
I will see if the relay out of my CRX will work . I changed the cap and rotor ,wires
Thanks
Jac
PINKFIFFTY
Jul 6, 2016 01:16 PM
brutus101
Jun 30, 2005 07:16 AM
P-DuBB
Apr 12, 2005 08:44 PM
AC2i0v0i0c
Oct 18, 2004 11:31 AM
boondox_saint
Jul 4, 2004 10:25 AM
