Help with 92 DX wont start
I have fuel and spark, But wont start . Any ideas on where to go from there ?
Will the injectors not work with a bad ecm? I sprayed gas in throttle body and still nothing?
Thanks
Jac
Thanks
Jac
Re: Help with 92 DX wont start (KNO3)
Hello , yes it turns over and has spark,fuel to the fuel rail . Sprayed fuel in throttle body and still nothing happening. could this be the ecm ? i thought it would run without the ecm disconnected? Or i was thinking it could be the dist. is shot but in that case i shouldnt be getting spark.
Re: Help with 92 DX wont start (jackzzz)
Open up your distributor. Check all your connections. If they're all fine, then you know it's not due to a poor connection. Take out your ignition control module and ignition coil. Get these tested. It might be one of these two components. Also, if it turns over, you might have a blown ignition fuse. It's under your steering column.
Re: Help with 92 DX wont start (mjrage)
Will the main relay make the fuel injection not work? I have spark and fuel to the injectors It should start. What does the main relay control?
Thanks
Jac
Thanks
Jac
PGM-FI or Program Fuel Injection is the main relay basically. It controls ignition, fuel pump, etc.. It could cause that problem or it could just be a distributor cap and rotor. Have you tried that?
Main relay will be anywhere from 35-65$ . I just bought one. I only could get it thru honda.
