B20VTEC Compression check results...
Old Jun 3, 2004 | 09:43 PM
Pandahatch's Avatar
Default B20VTEC Compression check results...
I did a compression check on my engine today since I changed everything and there still seems to be a seepage of oil somewhere. I came up with these results. This is a stock JDM P8R B20B bottom end with a stock B16A head. The car was ran for about an hour and the throttle is wide open. I cranked it around 6 times.
210-220-220-210
What do you think?
Old Jun 3, 2004 | 10:04 PM
mmuller's Avatar
Mad Scientist
Default Re: B20VTEC Compression check results... (PandaHatch)
looks good
Old Jun 3, 2004 | 11:09 PM
Pandahatch's Avatar
I hope so, it's running a lot better.
Old Jun 5, 2004 | 08:23 PM
bull2k4's Avatar
Default Re: (PandaHatch)
what's your compression ratio supposed to be?
Old Jun 5, 2004 | 10:52 PM
mmuller's Avatar
Mad Scientist
Default Re: (bull2k4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bull2k4 &raquo;</TD></TR><TR><TD CLASS="quote">what's your compression ratio supposed to be?</TD></TR></TABLE>
stock pistons+pr3 head should be about 10
Old Jun 6, 2004 | 11:17 AM
Pandahatch's Avatar
These are the low compression one's P3F's. I have the 97 spec B20B so 8.8:1 stock. With the B16A head. it's 9.1:1.
Old Jun 6, 2004 | 11:47 AM
wowpaw's Avatar
very nice
Old Jun 6, 2004 | 04:25 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PandaHatch &raquo;</TD></TR><TR><TD CLASS="quote">These are the low compression one's P3F's. I have the 97 spec B20B so 8.8:1 stock. With the B16A head. it's 9.1:1.</TD></TR></TABLE>
even better #'s then
Old Jun 6, 2004 | 04:46 PM
1.8turbolsvtec's Avatar
sorry for butting in i got a ? what do you think that the compresson would be on this b16 aftermarket pistons 9-1 in a b16 but in a lsvtec with a b16 head thanks for the help if you all can
Old Jun 6, 2004 | 05:28 PM
mmuller's Avatar
Mad Scientist
Default Re: B20VTEC Compression check results... (1.8turbolsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8turbolsvtec &raquo;</TD></TR><TR><TD CLASS="quote">sorry for butting in i got a ? what do you think that the compresson would be on this b16 aftermarket pistons 9-1 in a b16 but in a lsvtec with a b16 head thanks for the help if you all can</TD></TR></TABLE>
well, i dont really know what kind of pistons they are... but a rough estimate would be about 1.2/3 more compression so about 10.some
Old Jun 6, 2004 | 06:21 PM
Default Re: B20VTEC Compression check results... (mmuller)
the pistons are aris 9-1 for a b16
Old Jun 6, 2004 | 07:56 PM
bull2k4's Avatar
i just got finished building my b20/vtec.......i did a compression test today and got 300 across all cylinders
Old Jun 6, 2004 | 10:37 PM
Pandahatch's Avatar
With what pistons?
Old Jun 6, 2004 | 10:42 PM
2k.civic.si's Avatar
Default Re: B20VTEC Compression check results... (bull2k4)
300psi....so u maxed out your gauge? or u got a super expensive one for diesel motors that goes to 1000psi.....my snap-on compression gauge only goes to 300psi...and with 12.4:1 compression in a b18c with b16 head i maxed the gauge out...no idea how many psi....waiting on another gauge to show up....
Old Jun 6, 2004 | 10:43 PM
slowazzhatch's Avatar
http://www.c-speedracing.com
will answer all your compression questions...
and mine are 210-210-210-210 and i'm around 9.5-6:1 compression
Adam_b16a
Nov 30, 2009 08:29 AM
teamXteg
Apr 12, 2006 08:35 PM
BIGGINS LS-VTEC
Dec 16, 2004 09:04 AM
DOHCarp
Sep 11, 2003 07:10 PM
