car stalling?????
Old May 29, 2004 | 06:13 PM
chue_li's Avatar
Default car stalling?????
my ek sometimes stall when i come to a complete stop but not all the time. sometimes once a week or sometimes 5 or 6 times a day. i really don't know what the problem is , i have tried adjusting my timing and adjusting my trottle cable line so it will idle higher but neither works. my car idle's at about 500-600 rpm. and i think that is too low.
someone help me please.
thanks
Old May 30, 2004 | 03:24 PM
chue_li's Avatar
Default Re: car stalling????? (chue_li)
anyone????
Old May 30, 2004 | 03:28 PM
dohcMONSTER's Avatar
try adjusting your idle screw on your throttle body
Old May 30, 2004 | 03:30 PM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chue_li &raquo;</TD></TR><TR><TD CLASS="quote">my ek sometimes stall when i come to a complete stop but not all the time. sometimes once a week or sometimes 5 or 6 times a day. my car idle's at about 500-600 rpm. </TD></TR></TABLE>
The idle is about right (are you expecting it to idle at 1000 rpm?), but the stalling obviously isn't. This sounds like something that happened to me a few months ago. The engine would idle okay sometimes but then suddenly stall on other days. Turns out the valve lash was too tight. Readjusted it to stock settings, reset the idle per the Helms instructions, and all was well.
Old May 30, 2004 | 03:56 PM
chue_li's Avatar
Default Re: car stalling????? (Daniel)
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel &raquo;</TD></TR><TR><TD CLASS="quote">
i have just had my valves adjusted at a shop
Old May 30, 2004 | 05:20 PM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chue_li &raquo;</TD></TR><TR><TD CLASS="quote">.
i have just had my valves adjusted at a shop</TD></TR></TABLE>
As did I. Do you think just because they're pros that they don't mess up? That's like assuming Michael Schumacher never spins off. He spun like three times during practice this weekend. (Luckily he's better come race time.) Anyway, I talked to a service manager at my local Honda dealer, and he said to check the valve clearances, which I did. Turns out they were too tight. The mechanic who originally set the clearances at the independent shop no longer works there. I hope it isn't due to his mechanical ability because he's worked on my car before w/o a problem. That's my $.02. It may not be the solution to your problem, but I experienced similar symptoms, and readjusting the valves made it go away.
redED9Si
Aug 21, 2005 06:58 PM
kb158
18
Jul 30, 2004 02:43 PM
6thgen4u2nv
11
Jan 11, 2004 03:19 PM
EFStali
10
Aug 19, 2003 09:14 PM
MeanGreenEG9
Mar 6, 2003 09:19 PM
