Crappy idle, almost no idle on EK
here's the problem:
when the car is cold, it does the jumpy idle dance, when it warms up it goes away, but then it idles and then dies.
here's what I tried:
took off the IACV, cleaned it up, nothing
tried to adjust the idle by the screw on the TB ( on the top part, i read on h-t that it adjusts idle, it didn't do anything), with the TPS on and off...
Now im starting to think the timing may be off, i bought the car built, so I didn't do any of the work...say what you like...im just trying to make it so my car can idle and I don't have to rev it up at lights...
Multi-paradigm
Re: Crappy idle, almost no idle on EK (6thgen4u2nv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6thgen4u2nv »</TD></TR><TR><TD CLASS="quote">
Did you just turn the screw to adjust the idle? It might not work that way...
The engine has to be up to normal temp, and you have to disconnect the 2P connector from the IACV. Then start the engine with your foot on the gas a little, and let it hang at about 1000RPM. Then release slowly and let it settle into its idle. THEN you adjust the idle screw.
And then, before you reconnect the 2P connector to the IACV, TURN THE IGNITION OFF. Then reset the ECU.
no CELs, im thinking its the timing, im gunna reset the cam gears back to 0 degrees also, i just gotta get a timing light, and a day of no snow, its been a winter wonderland the past 2 weeks. only thing thats good about it is the snow dorifto!
1 Post
Re: (6thgen4u2nv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6thgen4u2nv »</TD></TR><TR><TD CLASS="quote">no CELs, im thinking its the timing, im gunna reset the cam gears back to 0 degrees also, i just gotta get a timing light, and a day of no snow, its been a winter wonderland the past 2 weeks. only thing thats good about it is the snow dorifto!</TD></TR></TABLE>
also check that the cams are properly in time with each other,and the crank.then set the ignition timing.
chris
chris
Re: (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">
chris</TD></TR></TABLE>
yes do that. solved a big problem on my friends car. cept he let it go on to long and had a couple of bent valves
