More power for daily driver (on the cheap end)
Ive asked all sorts of stupid questions about motor swaps and stuff but now that Ive researched tons I would now like the advice of others.
I have an 88 civic dx for my daily driver. I just bought it off the original owner and Ive been cleaning it up and what-not. Its been a long time since it had a tune up and the timing belt needs to be changed soon, and I got to thinking...
Ive been reading alot about "mini-me" swaps. From what I understand its a SOHC VTEC head on a non-vtec block, correct? Ive read that it makes a decent power increase and its cheap, which is exactly what I am looking for.
Now this is where I ask the questions. PLEASE dont give me responces telling me to search, because there is ~150 or so threads on mini me swaps and I dont have that kind of time to read all of them . If you have info on the questions I am asking, please share.
1. Can I use my block that is in the car now, whatever that is??
2. What head EXACTLY will I use for the swap on my car?
3. What additional parts will be needed?
I plan on rebuilding the head with OEM honda parts before installation to ensure reliability.
Sorry if this is a "noob" thread but we all start somewhere, right?
Thanks in advance
Thanks in advance
https://honda-tech.com/zerothread?id=554053
That should help. Either post questions there, or IM Bauley Civic if you need more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by libila »</TD></TR><TR><TD CLASS="quote">Thanks for the link, that is very helpful.
One question, is that the same engine in my 88? It says its for a 92-95.</TD></TR></TABLE>
It's virtually the same. Most of the info will apply to a d15 block of any generation. The things that may be different in your application will come down to OBD compliance.........
ok your block would be a d15b2, not the greatest for minime but it'll do fine
you can use either the z6(92-95 civic si) head or
a y8 head(96-00)
dont quote me on this one but i believe if you use the y8 head you can use your stock dizzy
if your car is dpfi you need to convert to mpfi...also for vtec activation you can either do a rpm activation switch or else you can convert to obd1 or obd2
a y8 head(96-00)
look at the front of the motor. On the left hand side of the heat shield/ exhaust manifold, you will see a stamp on the block that will give you teh engine code.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by libila »</TD></TR><TR><TD CLASS="quote">I cant see the block number, its dark. Where would it be located?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by libila »</TD></TR><TR><TD CLASS="quote">I cant see, its too dirty
sounds like you need to hire a maid to clean up after you then. j/k
just grab some de-greaser and wipe off that area.
</TD></TR></TABLE>sounds like you need to hire a maid to clean up after you then. j/k
boosted_zc
13
Jun 19, 2009 03:06 PM
Angry Domo
16
Aug 23, 2004 08:57 PM
