rattling short shifter!
Old May 26, 2004 | 07:43 AM
aeon's Avatar
Default rattling short shifter!
well i've searched and did almost everything people did to fix their rattling shifters but none of them seem to fix my rattling problem. I was driving the other day and noticed when i pull the shifter back with a little bit of pressure, then the rattling goes away. i was thinking that by maybe buying a new weighted shift ****, it might fix the problem a little. anyone know what i can do here?
Old May 26, 2004 | 07:57 AM
1Bar GSR's Avatar
Default Re: rattling short shifter! (aeon)
Replace your shift bushings... when mine were going bad at high rpms it would rattle. Once I replaced it you have to let it wear in but once it wears in it should be great! They are only like $20.
Nick
Old May 26, 2004 | 08:01 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeon &raquo;</TD></TR><TR><TD CLASS="quote">well i've searched and did almost everything people did to fix their rattling shifters but none of them seem to fix my rattling problem. I was driving the other day and noticed when i pull the shifter back with a little bit of pressure, then the rattling goes away. i was thinking that by maybe buying a new weighted shift ****, it might fix the problem a little. anyone know what i can do here?</TD></TR></TABLE>
What kind of shifter do you have? Does it have metal bearings in the bottom, or did you have to transfer over parts from the stock shifter?
Most likely the cause is too much freeplay on the through-bolt. I used washers to take up the space on my short shifter, no rattles for almost 3 years now.
Old May 26, 2004 | 08:05 AM
aeon's Avatar
I got that short shifter from one of our sponsers. also i'm using energy suspension bushings. and yes i had to tranfer parts from the stock shifter over. i guess i'll try using some washers and see if that'll work. how many washers did you use and what size??
Old May 26, 2004 | 09:00 AM
Community Builder
Default Re: (aeon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeon &raquo;</TD></TR><TR><TD CLASS="quote">I got that short shifter from one of our sponsers. also i'm using energy suspension bushings. and yes i had to tranfer parts from the stock shifter over. i guess i'll try using some washers and see if that'll work. how many washers did you use and what size??</TD></TR></TABLE>
Ehh I hate shifters that don't have metal bearing in the bottom (B&M)
I used the spacers which came with my shifter, which prevents the thru-bolt from being overtightened, and then several stainless steel washers and 1 lock washer to keep everything pressed together and rattle-free.
Old May 26, 2004 | 09:23 AM
spoolindc2's Avatar
I think B&M's are great... Mine has been problem free for almost a year now... i just replaced all the parts w/ new ones and used urethane bushings.... someone doesnt know what they are talking about ........
Old May 26, 2004 | 09:30 AM
ru2slo's Avatar
Default Re: (rjride1020)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjride1020 &raquo;</TD></TR><TR><TD CLASS="quote">someone doesnt know what they are talking about ........</TD></TR></TABLE>
ouch..
[not instigating]
b&m are the greatest though.. strongest too.. i broke two skunk2s :[
Old May 26, 2004 | 09:33 AM
vain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjride1020 &raquo;</TD></TR><TR><TD CLASS="quote">I think B&M's are great... Mine has been problem free for almost a year now... i just replaced all the parts w/ new ones and used urethane bushings.... someone doesnt know what they are talking about ........</TD></TR></TABLE>
B&M states it in their instructions .. to reuse the old bearings. if you were smart (and didn't listen to them), i suppose you would have bought new ones. but regardless, unsealed bearings suck.
Old May 26, 2004 | 09:41 AM
Community Builder
Default Re: (vain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vain &raquo;</TD></TR><TR><TD CLASS="quote">
B&M states it in their instructions .. to reuse the old bearings. if you were smart (and didn't listen to them), i suppose you would have bought new ones. but regardless, unsealed bearings suck.</TD></TR></TABLE>
indeed, and that rubber o-ring junk that you have to put in there
Don't know what I'm talking about? I've driven 2 different cars with B&M shifters and I thought they sucked. They still had the rubbery feeling of the stock shifter, which my short throw did not have even with STOCK bushings. I also hate how the shift **** sits farther away from the driver.
Old Jun 7, 2004 | 01:54 PM
aeon's Avatar
well, i've tried adding some washers and that doesn't seem to help. tried switching my bushing back to stock and i think that made it rattle a little more. tried turning the shifter around so that the reach is a little further and that seemed to help out a bit, but i don't like having the shifter further. can't use the cup holder when it's like that. anyone have any other answers to this??
Old Jun 7, 2004 | 03:26 PM
vain's Avatar
Default Re: (aeon)
could the pivot be hitting your exhaust pipes? or is it not that kind of rattling? can you describe the rattling sound?
Old Jun 7, 2004 | 03:36 PM
Community Builder
Default Re: (aeon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeon &raquo;</TD></TR><TR><TD CLASS="quote">well, i've tried adding some washers and that doesn't seem to help. tried switching my bushing back to stock and i think that made it rattle a little more. tried turning the shifter around so that the reach is a little further and that seemed to help out a bit, but i don't like having the shifter further. can't use the cup holder when it's like that. anyone have any other answers to this??</TD></TR></TABLE>
Does your short shifter have metal bearings in the bottom? I don't think you ever said. If not, I would get a short shifter that does.
Old Jun 7, 2004 | 05:15 PM
HiRevn's Avatar
Default Re: (PatrickGSR94)
I have a B&M and it rattles like crazy, but only at certain speeds/RPMs
Old Jun 7, 2004 | 08:55 PM
aeon's Avatar
yeah mine uses the bearing from the stock shifter. the rattling sounds like the shift **** is loose, but when i take the shift **** off, the rattling is still there. and no i don't think it's hitting the exhaust, i've already checked. it seems to be rattling in every gear and it's driving me nuts!
Old Jun 7, 2004 | 09:16 PM
Seedc2's Avatar
Default Re: (aeon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeon &raquo;</TD></TR><TR><TD CLASS="quote">yeah mine uses the bearing from the stock shifter. the rattling sounds like the shift **** is loose, but when i take the shift **** off, the rattling is still there. and no i don't think it's hitting the exhaust, i've already checked. it seems to be rattling in every gear and it's driving me nuts!</TD></TR></TABLE>
my skunk2 is doing the same. I also have energy suspension bushings. It seems to happen in 4th gear when im cruising around 3-4 rpms. Sounds like my itr shift **** is loose... annoying
Extreez
Dec 13, 2007 08:09 PM
JLEK
Apr 19, 2007 10:08 AM
adobospoon
Apr 19, 2005 11:11 AM
Dohc.MAD
12
Mar 30, 2005 09:31 AM
blackjdmEKcivic
Feb 25, 2005 01:52 PM
