about to give up!!!
Old May 25, 2004 | 01:15 PM
wpgcivic's Avatar
Default about to give up!!!
well i did my b16 swap in my 89 dx and i had a idle prob and fixed it while riding with the a6 ecu, and now that i threw in the b16 ecu i have the erratic idle again...what can it be, all i did was switch the ecu's
Old May 25, 2004 | 01:22 PM
Kamin's Avatar
Default Re: about to give up!!! (wpgcivic)
bum ECU is possible. it does control the idle.
Old May 25, 2004 | 01:28 PM
wpgcivic's Avatar
it better not be cause its the only one i got..
Old May 25, 2004 | 01:39 PM
devnull's Avatar
Did you swap the TPS sensor wires? the outside are backwards then what the B16A needs.
The DX is Multi-Point right not PGM-FI?
It would be easier if I could look at it...
Need more info...
Old May 25, 2004 | 02:56 PM
wpgcivic's Avatar
well if i did switch those wires then wouldnt it do this with the other ecu?
Old May 25, 2004 | 07:12 PM
wpgcivic's Avatar
plz help
Old May 25, 2004 | 07:22 PM
iowarex72's Avatar
Default Re: (wpgcivic)
switch them. the old ecu reads them right, thats why it runs ok with that one, you need to switch them for the B series ecu.
Old May 25, 2004 | 08:11 PM
wpgcivic's Avatar
hey i jsut found out my b16 ecu is a auto one...could this have anything to do with it??
DailyDriverXsi
May 4, 2011 09:25 AM
Fo-Do Fanatic
Feb 19, 2010 12:15 PM
eLeCtRoNSi00
Apr 16, 2004 01:17 AM
Adam.C
Mar 29, 2004 02:22 PM
