Burning oil????
Old May 21, 2004 | 10:51 AM
allicedout's Avatar
Default Burning oil????
My cousins civic si (canandian) with the D16Y8 is loosing oil. He had a oil change dun a week and half ago and now his level is a little below the bottom hash mark on the dipstick. he's puffin smoke at high RPM but other then that it seems fine. there are no visable leaks in the engine bay. anyhelp or thoughts of what it is would help. thanks
Old May 21, 2004 | 11:21 AM
MAKAROV's Avatar
Default Re: Burning oil???? (allicedout)
search
Old May 21, 2004 | 11:31 AM
AutoXer's Avatar
Default Re: Burning oil???? (EJ8GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8GSR &raquo;</TD></TR><TR><TD CLASS="quote">search</TD></TR></TABLE>
At least he explained his problem in a coherent mannar and used punctuation.
How many miles (Km) does it have? Sounds like the engine might be getting tired. How many miles since the oil change? Has it ever burned oil before now? Most hondas do, I know my Y8 goes through 1/2 - 1qt between oil changes.
Check the bottom of the oil fill cap, see if there's any foam or residue. Do a compression test, and if you have compressed air available, a leakdown test. That should narrow things down a bit for you.
Old May 21, 2004 | 12:10 PM
MAKAROV's Avatar
check your pcv valve
https://honda-tech.com/zerosearch
Old May 21, 2004 | 01:33 PM
allicedout's Avatar
Default Re: Burning oil???? (EX_AutoXer)
The car has about 140,000KM on it ummm its been burning slight oil for a while but not this much. I'll go thorough what u mentioned and see if i can narrow it down. Thanks for the info.
Nicks95GSR
Sep 28, 2007 10:54 AM
Probot
Aug 23, 2007 12:46 PM
redLUDEs2k1
Oct 12, 2005 10:21 AM
bigslimdog
42
Mar 27, 2004 03:02 PM
d9h
Jan 31, 2004 11:58 PM
