cheapturbos.com t3/gt35 "blowzilla" or full race's t3/t67
just wondering what would be a better street turbo on a 1.6 dont mind lag but want something thatll hit boost at 5500- 6k rpms the goal max is 500 , but more realistically is 400 - 450, will be using a fullrace manifold and 3inch downpipe
hey you just hit 2200 posts
i'd say the blowzilla, if thats the one i'm thinking it's dual ball bearing right?
compressor: GT35
.70 a/r
61mm inducer
flow: 65 lbs/min 832cfm
turbine: T3
your choice of .63a/r or .82a/r housing
stg3 turbine wheel standard
thats all it says on the site i dont think its DBB =\
.70 a/r
61mm inducer
turbine: T3
I think the blowzilla will have quicker spool but im positive that the t3/t67 will have insane top end power (more than the blowzilla). I would consider boring out that 1.6 because there will be a considerable amount of lag with eithier of these turbos, unless you are reving to 9500 rpms
i dont know if your gonna like either turbo , but they will both supply big hp . Boostedhybrid isnt happy with the t3/67 response on his 1.8, i can only imagine the 1.6. then again he isnt pushing alot of boost to it.
It doesn't matter if he revs to 20000, lag is lag.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedsiR »</TD></TR><TR><TD CLASS="quote">I think the blowzilla will have quicker spool but im positive that the t3/t67 will have insane top end power (more than the blowzilla). I would consider boring out that 1.6 because there will be a considerable amount of lag with eithier of these turbos, unless you are reving to 9500 rpms
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FwdCivicHatch »</TD></TR><TR><TD CLASS="quote">It doesn't matter if he revs to 20000, lag is lag.
ya but you wont drop out of the point of full boost, yes the motor goes to 9500 - 9800 rpms the shifts from there usually land me back at 6200 - 6500 on the 1- 2 -3 shifts so something thatll spool around that would be good, i dont mind lag i like hooking up on the street i dont want something that makes full boost before 5200- 5500 rpms
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Javier »</TD></TR><TR><TD CLASS="quote">get ahold of boostfed...he runs a T4/T67 on his 1.6L
84mm bore B16A 1.71 liter
27-28psi
Yeah I LOVE MY FULL RACE T4/T67 and my lil ole B16A!
Also my turbo hits full boost 6700 rpm due to the large T4 housing and P trim wheel, the 3 turbine housing WILL spool much quicker/sooner and prolly wpuld be a great turbo for you. I know of a ceratin board member who made 628whp on the Full Race T3/T67 and he loves it.
27-28psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">Boostedhybrid isnt happy with the t3/67 response on his 1.8, i can only imagine the 1.6. then again he isnt pushing alot of boost to it. </TD></TR></TABLE>
he is running a *stock* GSR motor, with an extremely conservative tune. i dont feel that is a fair comparison, especially since he has experience with true gt series dual bb turbos, not the bushing downgraded versions like cheapturbos or precisions sc61. very few people can afford a GT turbo, or have experience with them.
if you want a GT turbo we can probably give you some of the best prices around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic »</TD></TR><TR><TD CLASS="quote">better be running at LEAST 15pds with either of those turbos</TD></TR></TABLE>
You would be suprised, these turbos are suprisingly effiecient at lower boost. 400whp has been made with under 15lbs
Mugencrxsir1
Feb 26, 2006 04:17 PM
