Capping off oil line??
Old May 20, 2004 | 08:20 PM
Rod.'s Avatar
Default Capping off oil line??
Can I just cap off that part where that hose goes? What is it for anyways???
Old May 20, 2004 | 08:39 PM
mmuller's Avatar
Mad Scientist
Default Re: Capping off oil line?? (redturbocivic)
that is you breather box for the pcv system
its not an oil line so if you want you can just cap it off; i dont know why you would want to do that though
Old May 20, 2004 | 08:44 PM
Rod.'s Avatar
Default Re: Capping off oil line?? (mmuller)
I was looking on my new block and it does not have the holes for that pcv system
Old May 21, 2004 | 05:05 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">I was looking on my new block and it does not have the holes for that pcv system</TD></TR></TABLE>That's because on the newer engines the PCV valve is in the valve cover. You don't want to use an old valve cover with a new block, because then you won't have a PCV valve at all.
Old May 21, 2004 | 05:21 AM
Rod.'s Avatar
Default Re: Capping off oil line?? (JimBlake)
I am going to be using a vtec head though. I do not know how I am going to have a pcv system now
Old May 21, 2004 | 05:30 AM
acy76's Avatar
You can replace the breather box setup with a catch can. That way, you can run a PCV on the can if you like. I chose the Endyn kit, which eliminated the hose you refer to, as well as the black box and factory PCV.
Old May 21, 2004 | 04:16 PM
Rod.'s Avatar
Default Re: Capping off oil line?? (acy76)
Thank you everyone. I just bought the endyn kit today and hope to install tonight
slowassBubble
Jul 25, 2012 06:30 PM
EK_vzla
Mar 18, 2008 05:34 PM
93egallmotor
Apr 21, 2007 01:45 PM
JMinSi2000
Nov 4, 2004 09:33 AM
xci_ed6
Oct 2, 2003 09:15 AM
