Civic EX Turbo running lean
I have a 94 Civic EX turbo (Apexi ball-bearing) with 310 saturated injectors, performance fuel pump, FMU and in the middle of the gears (like 3000-4000 RPM) there is a hesitation with the motor and you hear "pop, pop, pop" from the exhaust, the air/fuel gauge goes from rich to lean. It started happening after 3 months of use. I changed out the fuel regulator and checked all vacuum lines. It just started today on my way home from work. What is going on with my engine/turbo/fuel?
