Speedometer does not work
Old May 19, 2004 | 02:51 PM
xero2hero's Avatar
Default Speedometer does not work
Ok i've got a 00' DX, I put a 99 EX motor in it because the old one blew out. With the swap I had to swap ECUs and now my speedometer/tripometer/odometer. I used the same tranny so I would think the speed sensor would still be good. What needs to be checked and how can I check it. The 99 i pulled the motor from was wrecked and my SRS light is on....I dont know how this could cause a problem but if it helps let me know. Also I have an extra plug on my harness next to the ECU but the ECU/Harness are from the same car and thats how it was hooked up before.
Old May 19, 2004 | 03:07 PM
Ekasey's Avatar
Default Re: Speedometer does not work (xero2hero)
is the speed sensor plugged in, if you jack the car up in the air and drive it does the sensor make voltage?
Old May 19, 2004 | 04:27 PM
xero2hero's Avatar
Default Re: Speedometer does not work (eLusive ek4)
speed sensor is plugged in, I will have to check on the voltage.......should it create voltage on its own....or will I have to leave it plugged in and splice wires to check?
Del_Slo_b16
Jul 23, 2012 10:38 AM
nickmk3
Transmission & Drivetrain
Mar 28, 2010 04:08 PM
ohsnapzafingcu
Sep 11, 2008 04:33 AM
NOman0608
May 26, 2007 05:19 PM
xero2hero
May 19, 2004 07:23 PM
