speed sensor malfuntion.
ever since the swap,
i been gettin the speed sensor malfunction.. i disconnect speed sensor, and plugged it back in and still gettin the code.
any help would be appreciated.
Re: speed sensor malfuntion. (BlueIntegraBoy)
there are plastic pieces that go inside of the little harness that you could try tot kae out and then plug back in for a better connection. clean them up a bit to.
Re: speed sensor malfuntion. (aaron_morris)
be sure to check the inside of the plug. just last month i was having this problem, turns out that one of the pins inside the harness plug was streatched and not making a connection.
