Need help removing axles
Old Nov 7, 2001 | 02:28 PM
DragII's Avatar
25 Year Member
Default Need help removing axles
got the hub nut off, removed the lower strut nut, and the castle nut on the LCA, tried to use a puller, but the friggin ball joint won't separate
is there an easier way of doing this?
Old Nov 7, 2001 | 03:27 PM
BreakStuff's Avatar
New User
Default Re: Need help removing axles (DragIIcivic)
Just loosen the castle nut and leave it on the lower ball joint, now take a big *** hammer and whack the LCA where the ball joint sits, try to avoid hitting the castle nut
Old Nov 7, 2001 | 04:05 PM
DragII's Avatar
25 Year Member
Default Re: Need help removing axles (BreakStuff)
ok, so hit it from the side? which direction should the blow come from?
Old Nov 7, 2001 | 04:10 PM
BreakStuff's Avatar
New User
Whatever side has the best angle to swing the hammer, I do it from the rear of the hub...
Old Nov 7, 2001 | 04:16 PM
DragII's Avatar
25 Year Member
cool, I'll give that a shot...what should I expect...for the LCA to just pop down onto the castle nut...then just remove it, and pull the hub away? correct?
Thanks for your help BreakStuff
Old Nov 7, 2001 | 04:36 PM
BreakStuff's Avatar
New User
You got it bro!
Old Nov 7, 2001 | 04:42 PM
DragII's Avatar
25 Year Member
sweet...you da man
93JDM_H22
Mar 12, 2009 04:20 AM
ice11honda
Aug 30, 2004 05:50 PM
Full Race A6
16
Feb 11, 2004 10:15 AM
See Are X
Feb 2, 2003 07:00 PM
FourthGenHatch
14
Dec 29, 2002 07:43 AM
