What Causes Brake Pads to Wear Unevenly? Help me correct this problem
Old May 18, 2004 | 01:35 PM
spender1326's Avatar
Default What Causes Brake Pads to Wear Unevenly? Help me correct this problem
These are my used rear brake pads off of a 94 teg LS, with ABS.
What caused this? Bad shims, bad caliper? Rotors? Did the previous owner not install it right?
Thx.
Here are the images
http://www.imagestation.com/pi...g.jpg
Modified by spender1326 at 10:57 PM 5/18/2004
Old May 18, 2004 | 01:40 PM
greaseball's Avatar
Default Re: What Causes Brake Pads to Wear Unevenly? Help me correct this problem (spender1326)
can't see pics.
Old May 18, 2004 | 01:41 PM
SMZ GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spender1326 &raquo;</TD></TR><TR><TD CLASS="quote">
My guess would be rotors.
Old May 18, 2004 | 01:42 PM
slickboy's Avatar
New User
Default Re: What Causes Brake Pads to Wear Unevenly? Help me correct this problem (greaseball)
I have the same problem happening on one of my front brake pads on my 95 LS teg. I've been wondering if that has been causing the shimmy I get while braking.
Old May 18, 2004 | 01:47 PM
WiggiE's Avatar
New User
Default Re: What Causes Brake Pads to Wear Unevenly? Help me correct this problem (slickboy)
My guess would be a stuck caliper slide. Worst case would be a bad caliper.
Old May 18, 2004 | 01:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greaseball &raquo;</TD></TR><TR><TD CLASS="quote">can't see pics.</TD></TR></TABLE>
Can you guys see it now or still no
Old May 18, 2004 | 01:52 PM
Chris's Avatar
Either the shims or:
Since that is the rears, the piston is a screw type, so I would think that it IS NOT caused by a hung up piston.
Therefore, I would think that the cause is improper pad installation.
Reason I say that is, on the rears, it is important to line up the studs on the backing plate with the "+" indentation on the head of the piston, and if the studs are not in the grooves, the pads will either 1) be crooked and wear unevenly, AND OR 2) be hung up and not fully disengage, causing premature, uneven wear and rotor overheating
Old May 18, 2004 | 02:03 PM
Chris's Avatar
Default Re: What Causes Brake Pads to Wear Unevenly? Help me correct this problem (Chris)
also..if you see a dent or "shiny" spot on the face of the piston (the part with the "+" cut into it) where maybe the stud from the backing plate was rubbing on or poking into it and not "in the groove" then that may tell you it was not installed properly...?? I dunno
Old May 18, 2004 | 02:11 PM
Thx guys. Gota love HondaTech, so much info.
Old May 18, 2004 | 02:42 PM
dannylDAsport's Avatar
uneven rotors perhaps.
Old May 18, 2004 | 05:29 PM
Kusai.Nihonjin.Desu's Avatar
Default Re: What Causes Brake Pads to Wear Unevenly? Help me correct this problem (dannylDAsport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannylDAsport &raquo;</TD></TR><TR><TD CLASS="quote">uneven rotors perhaps. </TD></TR></TABLE>
You'd feel the car shake while you're braking, if this was the case...
Old May 18, 2004 | 05:40 PM
Sukebei Oni's Avatar
Default Re: What Causes Brake Pads to Wear Unevenly? Help me correct this problem (Nihonjin)
not the rotors. most likely not the caliper piston. not the shims. could be partly improper installation from not making sure that every thing is sliding smooth. make sure that all the places the caliper slides on are lube up and slide fairly smooth and easy. looks like the bottom sliding portion was hanging up. look at the caliper brakets and make sure there aren't groove worn into it from the pad.
Old May 19, 2004 | 03:17 PM
North_Texas's Avatar
Default Re: What Causes Brake Pads to Wear Unevenly? Help me correct this problem (Sukebei Oni)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sukebei Oni &raquo;</TD></TR><TR><TD CLASS="quote">not the rotors. most likely not the caliper piston. not the shims. could be partly improper installation from not making sure that every thing is sliding smooth. make sure that all the places the caliper slides on are lube up and slide fairly smooth and easy. looks like the bottom sliding portion was hanging up. look at the caliper brakets and make sure there aren't groove worn into it from the pad. </TD></TR></TABLE>
Some of this is right. Mine are like this. Its a 94 Civic with Abs and I went to Autozone and you will need to order a Abs Hardware Disc Kit. Something with your calipers or something. Just go ask and they'll help you out. Sorry can't remember what exactly they said. Hope this kind of helps.
DaCRXboi
Mar 14, 2006 09:59 PM
b16a2EBP
Mar 3, 2006 07:09 PM
low430
Oct 23, 2005 04:59 PM
FastNFurious
Mar 6, 2004 06:08 AM
gtowni3
Jan 30, 2004 07:40 PM
