oil pan question help for d16
Old Nov 6, 2001 | 03:39 PM
tararan's Avatar
Default oil pan question help for d16
does anybody know if a 92-95 ex oil pan will fit a 00ex??? thanks, i need a oil fitting and the one i got is welded in the old oil pan? any suggestion about this? im planning on putting the turbo this week... thanks again
Old Nov 6, 2001 | 04:00 PM
DragII's Avatar
Default Re: oil pan question help for d16 (tararan)
I don't see why not. it is essentially the exact same engine.
Old Nov 7, 2001 | 01:29 AM
HENRY's Avatar
New User
Default Re: oil pan question help for d16 (DragIIcivic)
I've HEARD they are swapable but I have never compared the two to see if it would bolt up. One thing I can tell you is that the 96-00 D16 oil pans are aluminum and not steel like previous years. That's why you can't have oil return flanges welded to them (unless the flange is aluminum as well). But the aluminum oil pan is better beacuse it disapates heat considerably better then steel. It's up to you which one to use. Keep in mind that drilling through the aluminum oil pan is a cinch too.
1992cxhatchB16A2
Oct 25, 2008 01:10 PM
K20A2 5 lug EG
Aug 6, 2008 11:50 AM
Stewie
Welding / Fabrication
Nov 9, 2005 08:38 AM
fandango
Jan 20, 2005 06:20 PM
GruvyTune
Nov 12, 2001 04:07 PM
