I think I figured out how to used the MSD Soft Touch Revlimiter to limit boost. Will this work?
Ok, I want to get the MSD Soft Touch Rev Limiter because I want to get rid of my fuel cut limiter and I want to make a boost limiter (and possible EGT limiter as well).
Now this was my idea. Run the warning wire off of my greddy gauge (or you can use a pressure switch) to a relay that switches the limiter between two pills. Either say 7000 rpm for my normal limiter and like 500 rpm for the boost.
Will this work? Can I use wiring to connect the pills to the limiter instead of just plugging this in? DAMN, I hope this works. I've been trying to think of a way to do this for a while and it just hit me.
-Matt
-Matt
DamonBoost
Oct 28, 2001 01:54 AM
