Valve cover oil leak...
O.K. I have a problem I recently replaced the valve cover gasket on my B16 and when I drive it, it freakin leaks a **** load of oil. Now this is a brand new gasket the only thing that I can think of is that I put it on to tight.
Well it's not cracked and I replaced it cause the old one started leaking oil. At first I though it was leaking from the cam seals but that's not the case it still leaks from the valve cover.
go get some silicone gasket sealer/maker stuff and seal her up. take your time and no one will ever notice it.
but yeah, if you tightened it too much (like, more than 12ft-lbs i think it is) then you'll squish it and it'l leak.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mansonteamsmyt »</TD></TR><TR><TD CLASS="quote">new gasket... honda bond... find out what the bolt patern is... torque to spec...
works everytime</TD></TR></TABLE>
yup, don't over analyze it. just redo it step by step and take your time
You have to put the Honda Bond (just buy a tube from Honda) on the corners where the arches from the cams end (the sharp edges)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96-EJ6 B18C »</TD></TR><TR><TD CLASS="quote">
Thats correct! My VTEC solenoid gasket was leaking badly and causing oil to form at the bottom of the head, check that
</TD></TR></TABLE>Thats correct! My VTEC solenoid gasket was leaking badly and causing oil to form at the bottom of the head, check that
