possible vc leak?
Old Mar 22, 2005 | 07:39 PM
.Ry's Avatar
.Ry
Default possible vc leak?
I recently had the valve cover gasket replaced by someone and now i have seemed to have lossed some oil do you tend to lose some oil when you replace it, or should i just take off the cover and put gasket sealer on?
Old Mar 22, 2005 | 09:12 PM
eda6's Avatar
Default Re: possible vc leak? (turner7205)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 &raquo;</TD></TR><TR><TD CLASS="quote">I recently had the valve cover gasket replaced by someone and now i have seemed to have lossed some oil do you tend to lose some oil when you replace it, or should i just take off the cover and put gasket sealer on?</TD></TR></TABLE>
The oil you lose when changing the valve cover gasket is minimal. The amount of oil lost is so small that it won't register on the dipstick. If the spark plug holes are oil free and the motor exterior is clean then your valve cover gasket is fine.
Yuta
Dec 12, 2015 05:27 PM
stupidasso15
24
Oct 5, 2011 12:49 PM
90CivicDaily
12
May 4, 2008 10:12 AM
seifer
Feb 22, 2005 06:01 AM
TaZ326
Feb 7, 2004 02:19 PM
