crank angle sensor... location and installation... help
Old May 13, 2004 | 02:45 PM
BRAWDY03's Avatar
Default crank angle sensor... location and installation... help
my ecu is flashing 4 times and i looked it up and said it was the crank angle sensor i just need help on finding it and repairing it. does anyone know where there is a detailed step by step procedure? its an obdo motor from a 90 civic
Old May 13, 2004 | 03:16 PM
RZProStreet's Avatar
Default Re: crank angle sensor... location and installation... help (BRAWDY03)
That sensor is located in the distributor. It is the center sensor rotor. You can check the pickup by measuring the resistance between the blu/grn & blu/yel wires at the distributor plug. It should measure 350-700 ohms. Also check the sensor rotor for any chips in the teeth.
Old May 13, 2004 | 04:50 PM
Chiovnidca's Avatar
Default Re: crank angle sensor... location and installation... help (RZProStreet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RZProStreet &raquo;</TD></TR><TR><TD CLASS="quote">That sensor is located in the distributor. It is the center sensor rotor. You can check the pickup by measuring the resistance between the blu/grn & blu/yel wires at the distributor plug. It should measure 350-700 ohms. Also check the sensor rotor for any chips in the teeth.</TD></TR></TABLE>
Also check the shaft for side to side play. (usually accompanied by brown dust)
Yuta
Oct 13, 2018 08:07 AM
Unphzd
Dec 13, 2010 11:30 PM
SwappedLSHatch
Apr 13, 2006 01:33 PM
Nvious R
Oct 28, 2003 06:27 PM
