will leakdown test findout if
Old May 12, 2004 | 04:10 PM
95gsr's Avatar
Default will leakdown test findout if
I have white smoke coming out my exhaust. Now i know this is coolant or running lean. now i am not 100% sure it white and not blue white. The thing is I just rebuilt my engine new head gasket and ctr pistons and rings. it is not tuned yet runnoing on stock p72 ecu, stock cams, and rc440 injectors. will a leakdown test tell me if the rings are cracked or head gasket is bad or something. I would rather have someone just tell me your running lean and i will be happy. so what do you guys think. Luis
Old May 12, 2004 | 06:54 PM
95gsr's Avatar
Default Re: will leakdown test findout if (95gsr)
TTT
Old May 12, 2004 | 08:18 PM
psychotic_z's Avatar
Check your spark plugs first; that can tell if you if you're lean or not. Then, check your coolant. Is it low? Do the simple stuff first. bump for the leakdown question, I don't know though. You shouldn't need to do one if you just rebuilt. Unless you smacked a valve with one of the PCT's... if you did then you'd be screwed a hundred ways more than running lean or blowing out coolant.
MYKJDM
Jun 16, 2007 08:57 AM
nub_pwn
21
Nov 12, 2006 04:24 PM
turbolude99
Nov 5, 2004 01:02 PM
calvinPGMFI
Apr 3, 2004 10:32 AM
All Motor EG
Jul 22, 2002 09:48 AM
