white smoke
white smoke
white/light grey smoke comes out of my exahust only when vtec kicks in, i got a 92 hatch with a stock GSR, is it just oil burning or do i have a leak somewhere?
Re: white smoke (nub_pwn)
yes white smoke means your burning coolent, end of story, black smoke means your running rich, blue smoke means your burning oil.......if i were you i would do a compression check and a cyclender leakage test
i was runing a po6 before i got my p72 thats the reason for the spark plugs being blacku think if i change em it would make a difference?im still using the same sprak plugs with the p72 , the only code that comes is o2 sensor from exhaust, its straight piping no cat welded headers to exhaust, it really stinks ............when i down shift white smoke comes out and when vtec hits white smoke comes out
Re: (nub_pwn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub_pwn »</TD></TR><TR><TD CLASS="quote">i thought black sprak plugs mean ur running lean, and the GSR motor is all stock</TD></TR></TABLE>
No white spark plugs means your running lean. Do a compression check like already said.
Re: (fasthatchb18c1)
Probably it's because you dont have a cat on it. My car blows out a puff of smoke when vtec hits. But it's a dark grey-black color. I have no codes and only my cyl 4 spark plug is carbon fouled. Have no idea why.
Re: (averyvm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by averyvm »</TD></TR><TR><TD CLASS="quote">I think itsyour valve seals. let your car sit over night and then drive it you see smoke in the morning while you drive even if your not in vtec then its your valve seals</TD></TR></TABLE>
That would be blue smoke. He has white smoke.
Blue=oil
white=coolant
black=unburned gas
(I you burn a lot of oil the smoke can look white, but its really not.)
Blue=oil
white=coolant
black=unburned gas
i tihkn it might be oil, cuz only after 4-5 k and let off throttle its looks white but kinda grey?!!?? still confused was thinking it was hte valve seals but when i start it up in the morning no smoke........
i think it might be oil in my spark plug tubes cuz i was changing spark plugs and oil today and i put in a new spark plug then took it out and there was oil on it? still confused
Re: (nub_pwn)
yea i have a similar prob. only when under load does it smokes white...i compression checked the motor, and all the numbers are even. how would u know if its your valve stem seals? how hard is it to do a leak down test?
DamonBoost
09-13-2001 05:03 PM
