how to: intsall ARP head studs?
Old May 12, 2004 | 09:31 AM
See Are X's Avatar
Default how to: intsall ARP head studs?
does anyone have instructions to install ARP head studs...they are going into a b16 if that matters.
Old May 12, 2004 | 09:35 AM
See Are X's Avatar
Default Re: how to: intsall ARP head studs? (See Are X)
do i need to use loctite?
Old May 12, 2004 | 10:11 AM
APEX CRX's Avatar
they are pretty straight forward on installing. did you get the instructions with them? Yes, use red loctite
Old May 12, 2004 | 02:45 PM
Rod.'s Avatar
Default Re: how to: intsall ARP head studs? (APEX CRX)
there is a thread on here on how install them
Old May 12, 2004 | 03:15 PM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">they are pretty straight forward on installing. did you get the instructions with them? Yes, use red loctite</TD></TR></TABLE>
i dont know where your getting your information from because the instuctions say NOT to use loctite or any other type of thread sealer on them unless your threading them into a coolant filled hole.
you thread them in dry and hand tight until they stop moving.
Old May 12, 2004 | 03:43 PM
buda18's Avatar
Default Re: how to: intsall ARP head studs? (non-VTEC)
do you have to retorque them after 1000 miles?
Old May 12, 2004 | 06:45 PM
Rod.'s Avatar
Default Re: how to: intsall ARP head studs? (buda18)
https://honda-tech.com/zeropost?cmd=tshow&id=279313
arp headstud install
Old May 14, 2004 | 06:47 AM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
you thread them in dry and hand tight until they stop moving. </TD></TR></TABLE>
I get my information from ARP direct. It does say you can use loctite for the studs other than a coolant filled hole. Did you want a pic of the instructions posted?
big-cat
Sep 14, 2007 12:54 PM
CRX_DOHC_ZC
16
Mar 11, 2006 09:24 PM
turbotime
Nov 12, 2005 02:06 PM
k24a4kid
Mar 12, 2005 10:42 AM
sikcrx80
Jan 8, 2004 10:24 AM
