ARP and Threadlocker? (search is down!)
Old Nov 12, 2005 | 09:42 AM
turbotime's Avatar
Default ARP and Threadlocker? (search is down!)
I got arp headstuds and the studs backed out a lil on the last install. I followed a,l directions and stuff correctly, im thinking there may have been air trapped in there.
Anyway I am putting the car back together after a headgasket change and was wondering if i could just threadlock the studs? I mean i shouldnt need to remove them, and the threadlock isnt 100% permenant.
I got some threadlocker RED (HIGH STRENGTH) and was going to give the block side thread of the arp stead a light coat to prevent backing out, one of its "listed purposes" is locking head studs.
What do you think? Good idea/bad idea? Please dont just quote me installation instruction like "use moly lube" or "use motor oil".
The question is wether or not to use the threadlocker.
thanks
Old Nov 12, 2005 | 10:46 AM
Turbo200's Avatar
Default Re: ARP and Threadlocker? (turbotime)
From what i have read ARP head studs need to be retorqued after several hundred miles. In some cases retorqued after 24hrs.
Old Nov 12, 2005 | 11:24 AM
turbotime's Avatar
Default Re: ARP and Threadlocker? (Turbo200)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo200 &raquo;</TD></TR><TR><TD CLASS="quote">From what i have read ARP head studs need to be retorqued after several hundred miles. In some cases retorqued after 24hrs. </TD></TR></TABLE>
10 heatcycles
Old Nov 12, 2005 | 01:01 PM
turbotime's Avatar
up
Old Nov 12, 2005 | 01:53 PM
ryan89crx's Avatar
if they need to be retorqued, threadlocker will kind of prevent that. it works both ways, bolts cant come out, but they also cant be tightened, therefore preventing you from retorquing your head
Old Nov 12, 2005 | 02:06 PM
turbotime's Avatar
yeah i just decided not to use it. I torqued the studs down and ill give them 4 hrs to release air then ill torque them again and put the head on
projectef
Nov 7, 2008 12:15 PM
freddysEF
May 23, 2007 01:26 PM
Flexin5
May 19, 2007 05:26 PM
eg6cusco10pt
10
Sep 23, 2004 05:39 AM
sikcrx80
Jan 8, 2004 10:24 AM
