innovate vs. plx300 wideband
Old May 11, 2004 | 01:16 PM
rextec's Avatar
Default innovate vs. plx300 wideband
well im in the market for a wideband and these are the 2 in my price range. anyone have any input on either units? im leaning towards the innovate because it has the datalogging cappabiliteies where as the the plx doesnt (to my understanding)
thanks
Old May 11, 2004 | 04:36 PM
Jim Truett's Avatar
Default Re: innovate vs. plx300 wideband (rextec)
I have the PLX M500 and the datalogging is excellent. It's $500 though. If you use Uberdata, version 1.6666 has good datalogging and the M300 will work good.
Old May 11, 2004 | 07:46 PM
rextec's Avatar
Default Re: innovate vs. plx300 wideband (Jim Truett)
so i dont need the actual unit to have memory for datalogging, i can just use the ecu to datalog? im a bit confused now.
Old May 11, 2004 | 07:55 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rextec &raquo;</TD></TR><TR><TD CLASS="quote">so i dont need the actual unit to have memory for datalogging, i can just use the ecu to datalog? im a bit confused now.</TD></TR></TABLE>
Uberdata has datalogging built in. All you need to do is remove your stock o2 sensor, disable the o2 heater circuit in the ECU, then run the wideband output from the PLX M300 to the o2 input on the ECU. You would then connect your ECU to a laptop or other PC for Datalogging. You can make my USB cable for less than $15. Look Here: http://www.pgmfi.org/phorum/re...t=521 and here: http://www.ecimulti.org/uberdata/forum/
Old May 11, 2004 | 08:55 PM
PHiZ's Avatar
Innovate dataloggind is, um, underdeveloped.
-PHiZ
Old May 12, 2004 | 06:13 AM
DaX's Avatar
DaX
Loved
Community Favorite
I'm fond of the PLX device.
Old May 12, 2004 | 09:02 AM
rextec's Avatar
Default Re: innovate vs. plx300 wideband (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">Innovate dataloggind is, um, underdeveloped.
-PHiZ</TD></TR></TABLE>
what do you mean? is it not acurate?
Old May 13, 2004 | 07:51 AM
Aeka GSR's Avatar
New User
where can I get v1.6666? I cant find it, and when I do find it on the uberdata forums the link is broken.
Old May 13, 2004 | 11:13 PM
rextec's Avatar
Default Re: innovate vs. plx300 wideband (Aeka GSR)
bump!
Old May 14, 2004 | 04:05 AM
D@nnY's Avatar
to datalog with an innovative you need to buy a bunch of other stuff
-325 for the kit
-90-100 for the splitter with 5 channels
-20 rpm pickup
then it saves the info and you can open it on any computer and look at the air fuel per rpm and throttle...I might buy the plx or a techedge...i dont like how big the innovative is or the small display..
Old May 14, 2004 | 05:21 AM
civikdude's Avatar
Default Re: innovate vs. plx300 wideband (D@nnY)
Actually, datalogging has improved with their latest version of LogWorks. As for the $20 RPM pickup, that's only required if you're not pulling the data from the ECU (RPM/ICU wire). I have mine connected directly to the ECU and the readings are dead on. Also logging MAP, TPS and IAT.
I keep the Innovate in the glove box, and use my Autometer gauge as display (configurable serial output 0-1V). I will be purchasing their own 2 1/16" gauge when it becomes available within the month, which will have digital readout and a single button which will control the following:
- single click to start/stop record
- hold down for 2 sec to reset log
- double-click to review min/max holds
Overall, I'm very happy with the unit, for a price you can't beat.
Old May 14, 2004 | 05:54 AM
PHiZ's Avatar
Default Re: innovate vs. plx300 wideband (civikdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civikdude &raquo;</TD></TR><TR><TD CLASS="quote">Actually, datalogging has improved with their latest version of LogWorks. As for the $20 RPM pickup, that's only required if you're not pulling the data from the ECU (RPM/ICU wire). I have mine connected directly to the ECU and the readings are dead on. Also logging MAP, TPS and IAT.
Overall, I'm very happy with the unit, for a price you can't beat.</TD></TR></TABLE>
You got RPM working? How?
-PHiZ
Old May 14, 2004 | 06:10 AM
civikdude's Avatar
By pulling the signal directly from the ICM wire off the ECU. I do not have the RPM converter grounded, as that seemed to skew the values. Configured using the setup button and holding the engine at around 2000 RPM.
The RPM values with the Innovate match those retrieved from an OBD II scan tool.
Old May 14, 2004 | 12:20 PM
PHiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civikdude &raquo;</TD></TR><TR><TD CLASS="quote">By pulling the signal directly from the ICM wire off the ECU. I do not have the RPM converter grounded, as that seemed to skew the values. Configured using the setup button and holding the engine at around 2000 RPM.
The RPM values with the Innovate match those retrieved from an OBD II scan tool.</TD></TR></TABLE>
I've heard that that is how people have gotten it to work. The problem is, I had the GND going to sensor ground at the ECU harness. I would like to use the sensor ground for the sensors, but alas, it does not appear that I will be able to do that.
-PHiZ
98vtec
Jan 17, 2008 04:00 PM
jchrm80
10
Jan 25, 2007 09:00 PM
vtekstorm
Nov 15, 2004 05:56 PM
FragSyndrome
Apr 7, 2004 12:34 PM
Quetzolcotl
Apr 25, 2003 10:03 AM
