wide band o2
Old Oct 31, 2004 | 02:09 PM
vtekstorm's Avatar
Default wide band o2
quick question does the wide band o2 sensors work with the stock ecu.if so how would it be installed? and what is needed to be done for it to work correctly?
thanx guys
Old Oct 31, 2004 | 04:25 PM
gamakichi77's Avatar
Default Re: wide band o2 (vtekstorm)
yeahh..me also want the same answer........wanna use wideband on my VAFC in my B16A engine. thanks.
Old Oct 31, 2004 | 06:07 PM
vtekstorm's Avatar
Default Re: wide band o2 (acidburns_di)
im glad i wanst the only one who was thinking the same. come on ppl shed sum light on us and help us out
Old Oct 31, 2004 | 09:28 PM
drdisco69's Avatar
You cannot connect a wideband O2 sensor directly to the ecu. Most wideband display units have a narrowband output that will work with the stock ecu.
Old Nov 1, 2004 | 03:32 AM
civic-4-ges's Avatar
Default Re: wide band o2 (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">You cannot connect a wideband O2 sensor directly to the ecu. Most wideband display units have a narrowband output that will work with the stock ecu.</TD></TR></TABLE>
Old Nov 15, 2004 | 02:38 PM
forcedaccord95's Avatar
Default Re: wide band o2 (civic-4-ges)
what ia a good wide band to go with that does not cost and arm and a leg?
Old Nov 15, 2004 | 05:43 PM
f@sth@tch89's Avatar
Default Re: wide band o2 (forcedaccord95)
bump.....i would also like to know.
Old Nov 15, 2004 | 05:56 PM
PrettyLude's Avatar
plx m300, techedge, zeitronix, innovate lm1x, aem
Sir001
Engine Management and Tuning
Feb 12, 2017 07:21 AM
adamdecimals
Apr 1, 2010 01:05 PM
HONDA RR
Sep 16, 2005 03:53 PM
swtch7
Jul 15, 2005 03:19 PM
SCsol
Jun 18, 2005 06:20 PM
