A/F gauge install question...
Old May 10, 2004 | 01:00 PM
DruWO's Avatar
Default A/F gauge install question...
aight...i got the gauge hooked up to power and ground already...
i just need to know what wire i hook up the feed wire to.
i know i hook it up to the o2 sensor, but there are 4 wires??
Old May 10, 2004 | 01:02 PM
b16ahybrid's Avatar
Default Re: A/F gauge install question... (DruWO)
White.
A search would have yielded that, use it next time
Old May 10, 2004 | 01:05 PM
DruWO's Avatar
Default Re: A/F gauge install question... (b16ahybrid)
sorry about that...
thanks for the help tho' man...
Old May 10, 2004 | 01:07 PM
b16ahybrid's Avatar
No problem, thats what were doing here, learning and helping others
Old May 10, 2004 | 02:15 PM
Race Egr's Avatar
a/f gauges are crap just there for looks
Old May 10, 2004 | 02:25 PM
DruWO's Avatar
Default Re: A/F gauge install question... (ek-guru)
i want to have an idea of how my motor is running, because i don't want to lean it out when in spray..
and its mounted in a place where you wouldn't even be able to see it unless you peak into my window like you're going to steal my car or something...
peace out!..
Old May 10, 2004 | 02:40 PM
a1320honda's Avatar
i dont think their crap. your not supposed to use that as a stand alone tool for adjusting, but when combined with other gauges its very useful. i know alot of people who use a a/f gauge, egt, and oil pressure. and are making 3-5 hundred horse reliably. but that just my 2 cents
Old May 10, 2004 | 02:41 PM
b16ahybrid's Avatar
What he's trying to tell you is that they are not very accurate for use on any engine thats not stock.
Once your air/fuel ratio gets away from 14.7:1 it gets less accurate. So for your application your going to want to run a richer afr and it's not going to tell you much.
mine tells me i'm running lean most of the time when I know my afr is at 12.0:1 or close to. Tuning purposes they are worthless. If you like looking at the light going back and forth then it's worth the money, just don't invest to much trust into it being accurate
ECX
Audio / Security / Video
14
Dec 6, 2007 04:19 AM
ECX
Lighting
Dec 3, 2007 06:03 PM
perseverance
Jan 23, 2007 11:30 AM
Black R
Jun 25, 2003 11:44 PM
GOKOU
Aug 20, 2002 07:12 AM
